mbox pro 3rd and Protools 10.01 on mac OSX 10.7.3
Hi All
I have installed my macbook pro on a new ssd disc, with Mac OSX 10.7.3 and the newest ProTools version 10.01 I use the soundcard mbox pro 3rd. I can't sellect my soundcard to record from, i have sellected the mbox pro on the playback and set it to the Mbox pro 3rd in the input and output. But it don't work. If i try to sellect a input source on a track, i can see my internal soundcard with my internal microphone and the internal input. I can't see my MBox pro 3rd soundcard. I have set my default soundcard in the sound preferences in mac OSX to MBOX pro 3rd. It works on my old setup with osx 10.7.2. but what can i do, so it will work now. Thanks in advance. Best regards Jorgen |
Re: mbox pro 3rd and Protools 10.01 on mac OSX 10.7.3
There is a seperate driver you need to download and Install.
I have installed my device drivers, and i can't find another driver. Can you give me a link?
Check again Setup-> I/O Setup could be you must asign the input/output tracks manually.
Hi Again
I have tryed that, but it don't work. I can play sound from itunes or other programs to my mbox pro 3 soundcard. On my old setup i should find my mbox 3 pro in my input source on a track, but after i have maked a new installation on my new ssd disc, i can only find my internal soundcard on my input source. Is it possible to do something, so i can find my Mbox pro again in my input source on my track. What can i do? Thanks in advance. Best regards Jorgen |
I told you you need to download a seperate driver. It will fix all your problems. I will now also search Avids horrible site and post a link for you.
Here is the link
http://avid.custkb.com/avid/app/self...n&DocType=1450 You have to scroll down the page a little and click on Mbox Pro 3 gen of drivers. Which is under FireWire devices. I say this because the USB drives are above the Pro on the page. And could be confusing |
Hello Again
Thanks for the link, but before i ask in the forum, i have installed the firewire driver for the Avid Mbox Pro 3rd v1.0.14 , Is there other drivers, i should install, before i can sellect my mbox pro on the input source? Thanks in advance. Best regards Jorgen |
Hi Jorgen,
First go to Setup - Playback engine and choose your Mbox Pro and click OK. Then, as suggested, go to Setup - I/O Setup and choose the input page and then click Default. Do the same on the output page. Any help? -matts |
Hello Matts
I have tryed that before, and now i have tryed it again. It can't help me, i can't see my mbox under my interface in my input source. I can see it in io settings, but not in the input source. Thanks in advance Best regards Jorgen |
MBox 3 Pro and Protools 10? | JCBigler | Pro Tools 10 | 11 | 11-23-2011 08:20 AM |
ProTools white noise only with MBox 2 Pro not MBox 1? | qwertaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-26-2011 02:30 AM |
Need help with mbox 2 pro and protools LE 8.0.4 | Philleken | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-13-2010 11:49 AM |
protools can't see my mbox | elbowbetty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-01-2009 01:01 PM |
Protools LE for MAC using an MBOX | Merc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-30-2003 08:00 PM |
