Turbo Boost for Intel??
Am I meant to have this checked? even in tiny PT sessions, my laptop fan is going crazy with it on!
Re: Turbo Boost for Intel??
Uncheck it, won't hurt anything. On my intel Mac I leave it off unless I'm doing a lot of bouncing. That's the only time I can tell any difference. The rest of the time it's off and the fan stays at a normal rpm.
~Will |
If you lose a few MHz off your GHz of processing frequency, but there is enough time to get the calculations of your (potentially) 48 kHz audio at 32 bit crunched, you don't need boost to constantly running everything faster than needs to be to get playback steady.
With Boost On, every process might run fast, causing fan to run but potentially not affecting audio output, or necessary to keep up with audio. As mentioned smurfyou sees no performance hit unless bouncing. Then running full speed might be OK. Gets it done. Generally the fan running is not unsafe to be sure.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Try it both ways & see what works best for you. But do check all AVID optimizations, and also, check all AVID troubleshooting steps here: https://avid.secure.force.com/pkb/ar...oting/en367983
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Thank you, gonna turn off for now! will see how it goes
CPU Temps and Intel Turbo Boost | Chris August | Pro Tools | 25 | 05-14-2022 06:34 PM |
Intel MacBook Pro Fan/Turbo Boost | Chris August | macOS | 4 | 04-15-2022 12:24 AM |
Intel Turbo Boost 2021.6 | dominicperry | Pro Tools | 27 | 06-30-2021 05:35 PM |
Intel Turbo Boost Max 3.0 | Spyderrp7 | Windows | 8 | 07-14-2017 10:29 AM |
Intel Turbo Boost causing problems with PT 9? Anyone know how it be turned off? | Georgerob | Windows | 0 | 11-22-2012 03:13 AM |
