Old 02-01-2023, 07:02 AM
JCollet JCollet is offline
Default Logic Pro crashes if connected with S6
Hey guys,
pardon me if there's some info on this, but I haven't managed to find it so far:
We're running PT with HDX and S6 in the main room. Logic Pro in another room. Some time ago we started to also run Logic in the main room and ran into a quite annoying problem:
Once you do some changes to your mixer layout in Logic, like adding or rearranging tracks, you have to wait a couple of seconds before touching anything until S6 has arranged all the channels and the MM Home Screen. If not Logic crashes immediately, sometimes WS Control will go with it. Sometimes even immediately without you touching anything. Sometimes even small things like moving plugins or setting multiple tracks into rec mode will trigger the crash. Happens almost exclusively if the MM is on the Home Screen (not if eg "settings" menu is open). Logic then gives back "Logic was crashed during the use of EUCON plugin"-ish.
So I guess it's some kind of communication error between Logic and EUCON if too much information is transferred simultaneously. In PT everything works as usual.
We've tried pretty much anything we could thing of so any help would be appreciated.
We run 6,1 Mac Pros with Mojave and latest versions of PT, Eucon/Drivers and Logic.
Thanks so much already,
best,
Julian
Old 02-02-2023, 08:44 AM
EddieJones's Avatar
Default Re: Logic Pro crashes if connected with S6
Originally Posted by JCollet View Post
Hey guys,
best,
Julian
Is your Logic version 10.7.7 ? Apple did fix a bug for this recently. Also Monterey and up are better supported by Logic.
Old 02-02-2023, 08:49 AM
Hey Eddie,
Thank you! Yes, updated to Monterey and 10.7.7 recently, I have the feeling the responsibility is slightly better and I can put a little more workload on it before crashing, but still the same core problem…
Old 02-02-2023, 01:55 PM
EddieJones's Avatar
If you are fast on it we do see it still having issues. Will report to Apple again.
Pro Tools Crashes with Pyro AV connected PTcomposer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-21-2010 10:51 AM
PT (connected with canopus ADVC)crashes when re-open video session brenny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 08:43 PM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Win98-Laptop and 001 connected with new Magma CardSlot to PCI adapter? Audio Logic? Raskolnikow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2000 08:18 AM
LE/LOGIC/MTP-AV(USB) crashes.... **e** 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-07-2000 08:54 PM
