Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-17-2022, 08:02 AM
basslik's Avatar
basslik basslik is offline
Default Re: Mild Upgrade
Thanks Joel, greatly (MUCH greatly appreciate everyone's time.
Now I just need to figure out if I can still use the Digi~003 console with the Scarlette. I really like the console to be able to switch aux inputs in the push of a button and be able to switch instantly from two monitors, and the mono button is really useful as well.
If not then I'll just Slave the Digimax FS and reconfigure.
MAC PRO 2010 5,1 3.46hex 128ram - MOJAVE 10.14.6 - PT 2022.7 / 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 04-26-2022, 04:12 PM
basslik's Avatar
Originally Posted by JoelG View Post
It has been solid for me. For the amount of I/O you get for the money, and a brand with a decent reputation I don't think you can go wrong.
The Scarlette Mix Control is quite powerful and can provide a lot of routing options, but it can be a bit much to get a handle on. It is quite similar to my ProFire 2626 software, so I didn't find it too bad. I still have the 2626 connect to ADAT for another 8 mic pre's.
Joel
Scarlette sounds really good about now. Will make calls to see if it will rock & rock with my old Mac Pro.
Old 05-02-2022, 08:11 PM
basslik's Avatar
I'd move on from Firewire personally.
What is your price point?
How many pre's?
What OS version?
I've been happy with my Scarlette 18i20 (1st gen) and still have my old ProFire 2626 connected to it via ADAT for 16 mic pre total.
Joel
Hey Joel, got a chance on a great deal on a Scarlette18i20 2nd generation.
Researching now if it's compatible with my 2010 Mac Pro.
Old 05-02-2022, 08:27 PM
Sardi Sardi is offline
Your Mac Pro compatibility isn’t the issue. It’s a USB interface.
You need to concern yourself with driver support. Make sure the interface has drivers for the macOS version you’re running.
Old 05-02-2022, 08:31 PM
basslik's Avatar
Thanks Sardi. I'm looking into it now.
From what I read from USB 2.0 it doesn't sustain the speed as compared to firewire 400, even though the spec is at 480.
  #16
Old 05-03-2022, 07:49 AM
JoelG's Avatar
JoelG JoelG is offline
USB has more CPU overhead then firewire as I recall.. There is a bit of trade off, I've had good luck with my firewire interface too (ProFire 2626), but USB realistically has more of a future than firewire.
USB 2.0 has plenty of capacity for the 18i20's IO.
As Sardi mentioned, driver support is the key. Both to support your older Mac, and for new OS's that come out should you upgrade in the future.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 10 Pro
Pro Tools 2023 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #17
Old 05-03-2022, 08:31 AM
basslik's Avatar
Thank you both immensely.
  #18
Old 05-05-2022, 04:44 PM
basslik's Avatar
Joel
JoelG, may I ask regarding tracking.
I'm able to track 18 inputs with my003/DigimaxFS/SPDIF at 32 buffer at 48k.with a handful of effects.
What are you getting with the Focusrite/2626 ? Thanks.
Missing 1 qualifying license(s) for upgrade to Annual Upgrade Plan for Pro Tools 12 bangmusicdk Licensing & Accounts 0 11-12-2016 10:27 AM
Upgrade question - can I use mbox2 micro upgrade on 002 system? spreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2009 11:22 AM
5.1 upgrade..drivers? also is the D-verb demo an upgrade? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-21-2002 11:46 AM
(Mild) bug report.... Rail Jon Rogut Pro Tools TDM Systems (Mac) 1 06-20-2001 11:40 PM
(Mild) bug report.... Rail Jon Rogut Pro Tools TDM Systems (Mac) 0 06-20-2001 11:34 PM
