Old 12-23-2005, 03:09 PM
Soundworks UK Soundworks UK is offline
Default ProTools / Dolby signal flow PDFs
Hi, I've been looking at the post pro signal flow documents recently posted on digis site.
I'm sorry if it's obvious, but why would the Dialogue bus (for example) feed into Mono sub paths and go to Mono audio tracks rather than 5.1 paths and tracks?
I presume these tracks are stem recording tracks (so would they be set to input monitor most of the time i guess?)
Also, would you guys compress/limit and or insert global eq on (for instance) the dialogue bus? and if so would you use a master fader and insert compressors / eq's on those? or use aux inputs?
Sorry if I appear dim but am fairly new to mixing in the box when it comes to 5.1
Many thanks, Simon.
Simon Jones
Freelance sound creative. Bristol / Cardiff, UK
Re-recording mixer specialising in TV drama.
Mac Pro 2019 7,1 OS10.15.5, Protools ultimate 2020.5, UA Apollo 8 & 16.
Old 12-24-2005, 03:27 PM
Richard Fairbanks Richard Fairbanks is offline
Default Re: ProTools / Dolby signal flow PDFs
I am confused by your questions. Can you post a link to the documents you are talking about?
Very often dialog is stuck to the center channel. Of course there is nothing wrong with panning dialog when called for but for many situations there is no need to pan dialog, and until recently in broadcast there was an argument for NEVER placing dialog anywhere except center. These days you will probably never want to put dialog in the LFE channel, so dialog stems are only 5.0 or less. It has been a long-standing tradition in much broadcast mixing to save tracks (and system resources) by eliminating surround tracks in dialog stems. In fact I've mixed many shows where the dialog is ONLY in the center channel. In days gone by, for TV work, you could get by with music to L,R only, effects to L,R,S, and dialog to C. That is a total of six stem tracks for Dolby Surround, and dialog strictly mono! This is still a common approach, even if people don't admit it.
Call me by my real name, "Postman"
Old 12-24-2005, 03:56 PM
Avid's Avatar
Avid Avid is offline
Administrator
I'm guessing the reference is to the recently posted ICON Dolby Configuration drawings, in the ICON sections of Products and the Technical Document Library.
Administrator
Old 12-25-2005, 06:52 AM
Ah ha! Thanks for that point.
Another reason to consider mono tracks or mono bus's is to make solo more useful. It is often necessary to solo a single source from a mono track.
HTML code is On
audio signal flow in protools niros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2023 07:01 AM
Signal flow alexford67 Pro Tools 10 4 05-17-2012 10:38 AM
Signal Flow Questions scab666h8su macOS 4 11-30-2011 08:18 AM
Signal Flow? nate9 ICON & C|24 2 01-27-2009 07:46 AM
signal flow iamsaved General Discussion 5 01-31-2006 09:53 AM
