Old 05-18-2011, 10:32 AM
Nathan W. Nathan W. is offline
Default C24 newbie question 2 talkback mics
I'd like to use an external talkback mic in combination with the on-board talkback mic on the console. Basically, there's an "on off button / switch" on the external talkback mic itself. Now, if I go "main->Cue switch on" I can hear the other external talkback mic through the mains in the control room. So how do you route the external talkback mic to go directly to the cue's without being heard in the Mains? Also, haven't plugged the external talkback into the external talkback input because I want to use the built in talkback on the console.
Can BOTH internal & ext. talkback mics be active? nerdlinger ICON & C|24 2 09-10-2011 04:43 PM
Please help with talkback question! johnnyv ICON & C|24 1 09-10-2008 11:33 PM
Linking Listen Mics with talkback? Great Divide Studios ICON & C|24 12 10-08-2007 11:27 AM
New talkback mics for D-Control oscillations ICON & C|24 6 10-04-2005 09:48 AM
Internal talkback Routing for Procontrol newbie Shatner ProControl, Control|24, Command|8 2 03-15-2004 04:10 PM
