Old 03-11-2008, 10:00 AM
Mubeau Mubeau is offline
Default Digi please adress this Error, finally!!! 7.4 ?
Hey!
with 7.4.cs3 the automation error (if you change automation mode after a volume pass in trim mode)
ought to be removed.
BUT:
1. it is still present in large sessions with a lot of automation!
2. the error (press play and if you have a volume fader touched at the same time on the C24 - lets say -1 dB the automation is SOMETIMES written relatively on the TOTAL track!!!
3. session performance under 7.4 is extremely slow...
4. I´ve been reporting the automation errors since 2 years now and it gets annoying!
does anyone of you have these errors?
yes, Frank you already made the points with 7.4.
please!
Mubeau
PT.7.4cs3, 2x2,3Ghz G5, 2,5 GB RAM....
Old 03-11-2008, 01:14 PM
Default Re: Digi please adress this Error, finally!!! 7.4 ?
mmmmmmm...
and now i have to switch back to the session half day ago...
thanks digi!
Old 03-11-2008, 04:55 PM
emf1138 emf1138 is offline
This is still happening in cs3?? Hmm, that was one of the main fixes for this update. I'm doing my 1st mix tomorrow since updating. Here's to hoping it doesn't hit.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 03-11-2008, 05:15 PM
hi!
i also hope that for you...
it takes so much time to check and recheck things which may not happen during mixing sessions...
m.
Old 03-12-2008, 01:32 AM
Prepare for 9060 error on destructive record and punch. If I were you I´d stick with 7.3.1
I went back to 7.3.1 and now I can at least record to a track again without "unable to communicate with the hardware" errors.
frank.
PTHDn 2022.12 (OSX12.6.2), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 03-12-2008, 03:14 AM
steppenwolf68 steppenwolf68 is offline
frank.
Hi Frank, I had the same error ("unable to locate hardware")recently on a brandnew HD rig running 7.4. So, this is a known bug with 7.4. ????
Old 03-12-2008, 03:45 AM
frank.
Well, it´s known to me and I´ve mentioned it a couple of times here. Not sure what the cause is but it doesn´t happen with 7.3.1cs5.
Some have mentioned that it doesn´t happen with BWAV but I only run BWAV and it still happened in 7.4
frank.
Old 03-12-2008, 04:28 AM
hi frank!
hmmmm... i only switched to 7.4.cs3 because of the automation issue, but now....
Old 03-12-2008, 04:57 AM
hi frank!
Try before you run something important against the clock ;-)
fank.
Old 03-12-2008, 05:32 AM
yes frank, you´re right.
but I have this issue since i moved to PT 6.x !
so this is a very very old REPORTED story...
it´s simply not good if fear touching the fader, if you have to mix !
HTML code is On
D-Command's IP adress Hanswurstlsepp ICON & C|24 3 02-09-2011 05:20 PM
When is digi gonna adress the core audio/ reason issue?! mnolo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2010 12:43 PM
"Buss error" in thread "MainThread" at adress 0xbffe-nnn Delta Music Belgium Virtual Instruments 1 03-22-2007 06:29 AM
Digi customer service email adress down? Soundwise Pro Tools TDM Systems (Mac) 0 04-15-2003 11:43 AM
DIGI: Where to adress Beta bug reports? steins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-31-2002 06:16 AM
