Old 01-08-2012, 12:32 PM
TOOT88 TOOT88 is offline
Default 002 Rack firewire won't connect
My firewire light on 002 rack won't light up anymore, therefore there is a problem with 002 Rack firewire, internal issue. I read there is a part that Avid will send you, but I have no way to contact them.
I'm trying to get a part for 002 rack, but can't find a way to contact Avid to get the damn part. Spent 30 hours already trying to contact them. But all I see is ASC codes.
Old 01-08-2012, 10:22 PM
Default Re: 002 Rack firewire won't connect
The power harness is likely the issue. I would contact AllPro Electronics in Nashville as they are an authorized repair center, and should be able to get any part. Before you do that, you might try re-seating the harness as that fixes the issue about half the time. The rack is simple as you simply remove the top. With the front panel toward you, the PSU is on the right side. You can follow the harness from there to the 2 other connectors. Remove and reconnect all 3 connectors, 5 to 6 times(I would do the 2-wire connector on the PSU as well). replace the top(maybe with 4 screws for now) and test.
Can I connect my 002 rack to my PC using a firewire to usb cable adapter? oysterhead9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-01-2012 03:57 PM
Connect 003 Rack to a laptop w/o firewire? JackGasoline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-02-2011 07:33 AM
HELP! can't connect to 002 rack earworms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-07-2009 02:26 AM
I can't get my g5 to connect to my 003 rack!!! PhillyFresh Pro Tools TDM Systems (Mac) 2 02-12-2009 10:15 PM
002 Rack Can't Connect to PC Steel City 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-13-2006 01:38 PM
