I could use some advice
Hello,
Every time i want to start mixing my music in pro tools i notice that whatever i do the mix always sounds dull, flat and has no depth or width. The mixes just never seem to sound open or transparant. I've done recordings and mixes on other pc's with pro tools which always sounded good, so the problem isn't with pro tools, but probably with my pc. Could this be a summing problem? Could the motherboard or cpu be the problem? Could the problem be fixed with replacing either or both of these? I use pro tools le 7.3 with an mbox interface on a pc with windows xp pro. My motherboard is a asus p5 kpl-am se with a intel celeron e3300 cpu. I dont want to replace the entire pc (yet) so i could really use some advice. Kind regards, Tebbes |
Re: I could use some advice
Best place to start would be to post a Sandra report;
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Okay, this is what Sandra tells me:
SiSoftware Sandra Processor Model : Intel(R) Celeron(R) CPU E3300 @ 2.50GHz Speed : 2.5GHz Cores per Processor : 2 Unit(s) Type : Dual-Core L1D (1st Level) Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 (2nd Level) Cache : 1MB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 threads sharing Computer Mainboard : ASUS P5KPL-AM SE BIOS : AMI (OEM) 0602 09/11/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 2GB DIMM DDR2 Shared Memory : 8MB Channels : 1 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3) Video System Video Adapter : Intel(R) G33/G31 Express Chipset Family (8 SP 400MHz, 8MB DDR2 800MHz 64-bit, Integrated Graphics) Graphics Processor Storage Devices SAMSUNG HD503HI (500.1GB, SATA300, 3.5", 5400rpm, 16MB Cache) : 466GB (C:) (D:) WDC WD5000AAVS-00ZTB0 (500.1GB, USB1/SATA300, 3.5", 5400rpm, 8MB Cache) : 466GB (F:) Optiarc DVD RW AD-5240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 124GB (NTFS) @ SAMSUNG HD503HI (500.1GB, SATA300, 3.5", 5400rpm, 16MB Cache) Hard Disk (D:) : 342GB (NTFS) @ SAMSUNG HD503HI (500.1GB, SATA300, 3.5", 5400rpm, 16MB Cache) Optical Drive (E:) : N/A @ Optiarc DVD RW AD-5240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Extern (F:) : 466GB (NTFS) @ WDC WD5000AAVS-00ZTB0 (500.1GB, USB1/SATA300, 3.5", 5400rpm, 8MB Cache) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : T0 B0-73 Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semi Realtek 662 High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller USB Controller 6 : VIA VIA VT6214L USB UHCI Controller USB Controller 7 : VIA VIA VT6214L USB UHCI Controller USB Controller 8 : VIA VT6202 USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Network Services Network Adapter : Realtek PCIe FE Family Controller - Pakketplanner-minipoort (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Enhancing Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Not really, same monitoring but some were done in acoustically worse situations.
I do see that you have all 5400 rpm drives reported. I wouldn't expect that to impact the symptoms you describe, but the slow drives could be part of it I guess. 2 gb RAM is pretty lean, but again I would expect that would cause a performance problem, not what you describe. Bob |
Okay so today I did some good testing. With my computer I went to a friend of mine who has a good sounding home studio. I hooked up my mbox to his pc, loaded a session and made a simple, but pretty decent mix and bounced it.
We both use PT LE 7.3 so I could use the same plug-ins to make the difference as little as possible. Then I hooked up my own pc to his system, with the mbox, and loaded that session and listened to the mix. It was a huge difference!! The mix on his pc was the kind of mix I wanted it to be, open, transparant with good depth, but on my pc, again, I had the results I kind of expected. That made me decide to buy a new pc, with great specs, and at the same time to upgrade to PT 10. I'm still thinking about what kind of pc and what interface to use, so im just browsing this forum and the internet to make a final decision Thanks for the replies so far :) |
Your computer can't affect the sound quality. It can either run protools or it can't. Only the algorithms in protools (and plugins) and your audio interface have have an effect on sound quality. If your computer can't keep up with protools you will get error messages, choppy playback and stuff like that, but not a crappy sounding mix, that's just not possible.
Mac Pro help, advice.... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-03-2008 07:37 AM |
new and need advice | noisetree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-13-2006 07:39 AM |
Need Mix Advice! | vocalize | Pro Tools TDM Systems (Mac) | 5 | 11-13-2006 04:27 AM |
new and need advice | noisetree | Pro Tools M-Powered (Mac) | 2 | 11-12-2006 07:28 PM |
new and need advice | noisetree | Pro Tools TDM Systems (Mac) | 1 | 11-11-2006 10:08 PM |
