Small \"import audio\" dialog bug?
Hi all,
while doing some SRC tests today, I noticed that the "import audio dialog" in a PT 16bit BWAV session didn't give me the correct info when trying to import a 44.1kHz AIF file. It says: "example_44_1.aif file can be added directly to the current session or it can be converted tot the session's audio File type" PT seems to ignore the fact that the samplerate of the AIF file is wrong, although it will correctly convert it when "Convert" is selected. The same file in WAV format is correctly labeled: "example_44_1.wav file can be added directly to the current session, but it will play back at the wrong speed" This could be confusing in the heat of a session. Can anybody confirm this is a bug? Greetings, Thierry Tested on: PT7.2cs2 (wouldn't it be nice that PT mentioned the cs number in the "About Pro Tools" menu?) OS10.4.7 G5 Dual 2.7GHz with 8GB memory 1 Core, 1 Accel, 3 Process cards in a Digidesign Pro Tools Expansion Chassis, 13 Slot
http://www.a-sound.com/ |
Searching in Import Audio Dialog | Submersible | Pro Tools TDM Systems (Mac) | 2 | 05-20-2007 01:22 PM |
I cant preview audio in digibase or import audio dialog. | sammyfarr | Pro Tools TDM Systems (Mac) | 0 | 03-29-2007 01:16 AM |
Import Audio dialog , Can't select or play audio | Irl Sanders | Pro Tools TDM Systems (Mac) | 11 | 10-04-2006 02:02 PM |
5.1.1 Import Audio Dialog - another change? | barden | Pro Tools TDM Systems (Mac) | 1 | 06-29-2001 02:35 PM |
Import Audio dialog PROBLEM | jimlongo | Pro Tools TDM Systems (Mac) | 1 | 03-12-2001 03:32 PM |
