Bounce to Disk comes out Quiet and Muddy
When I bounce, I have my Master fader very low because I do most of my work late at night. But even when I raise the master fader to lets say -6db, its still fairly quiet and muddy after bouncing.
I'm using PT 7.3 LE. I select all, then File - Bounce to disk as BMF WAV. 24bit stereo interleaved. Can someone suggest a way to get my mixes to come out clean? Thanks for the help. |
Re: Bounce to Disk comes out Quiet and Muddy
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Thanks but I should have given more detail. When I say the mix comes out low, I mean really low. After the bounce, I take the wav file into Cool Edit and usually have to amplify the audio by 22db or more.
You should also search the DUC (and Google) for "gain structuring". The answer to your question exists in GREAT detail in the places I've suggested. You simply have to research the topic a bit. Did you try my above suggestions yet?
Thanks EGS. I haven't tried it yet since I'm at work. In the meantime I searched DUC and found a similar topic http://duc.digidesign.com/showflat.php?Number=937541 So I'm gonna go through that. And you're suggesting to research "Gain Structuring" definately will do.
Don't use your master fader as a source of volume control- If you're mixing at night and need to turn it down, do so by the volume knob on your interface. When you use the Master Fader for volume control you're essentially changing the sound of the overall mix (hence your low levels and muddiness)... Ride the faders into a wall- that'll help.
If you have to pull the master fader down a lot then you are in danger if clipping the mix bus before the meter all the time which is not what you want to be doing because you will be unaware of it. You should always trim back the tracks before you lower the master fader. It should stay at unity where possible. Whoever told you otherwise is wrong. While lowering the Master fader in a 24 bit mix will not degrad the audio fidelity untill lowered quite low the same can not be said for 16 bit. I suggest you do some more research on this as you appear to be a little confused
Garret
IMDB |
This document talks about the 48bit TDM mixer but applies to PT LEs 32bits floating point mixer too. Scroll down to the last half of the document. Garret, you might find it useful to read the whole thing.
Bounce Down Sounds Muddy | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-23-2008 06:59 AM |
Bounce to disk to quiet. | rageagainst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-22-2005 08:45 AM |
it's oh so quiet when I bounce to disk | marc_c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-21-2004 06:50 AM |
bouncing to disk - too quiet? | uiopuiop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-29-2003 09:22 PM |
newbie question: why once i bounce does it sounds so muddy? | mismagic | General Discussion | 1 | 06-08-2002 01:36 AM |
