Old 05-05-2006, 05:42 AM
www.Silentservice.de www.Silentservice.de is offline
Default New Magma PCIe to PCI Chassis
just seen that the Magma PCIe to PCI expansion chassis is available now. Is there any clue if this chassis will be supported by Digidesign?
There´s one main problem, Logic 7.2 is currently NOT working with the DigidesignHD Expansion Chassis (Configuration: G5 Quad 2.5 PCIe, DigidesignHD Expansion Chassis, HD4 Accel, running Apple Logic 7.2) while ProTools is running fine. Maybe we can get a statement why this is the case and what needs to be fixed to get this working?
Due to the reason that the DigidesignHD expansion connects to the host via ethernet maybe there´s the possibility to get the HD expansion working with the internal ethernet port on e.g. a MacBook Pro in the future? Just speculations...
SYS64738
Old 05-05-2006, 10:01 AM
uno1234 uno1234 is offline
Default Re: New Magma PCIe to PCI Chassis
Um, Logic 7.2 works fine here with the ExpHD and Quad 2.5. What doesn't work is ESB functionality, or Direct TDM. But Logic otherwise operates fine.
Old 05-05-2006, 11:44 PM
Exactly, ESB and EXS24 is not working. I use Logic for doing arrangements with many virtual instruments. If you want to use AU instruments there would only be the way to add another audio card and use DAE + CORE AUDIO drivers at once. That not the most elegant style.
I also had problems using the HD system together with a RME madi card (connection to Neve Capricorn), we had poor track count (60 tracks DAE + CORE AUDIO together!) and many crashes.
What is your configuration or recommendation for the above mentioned problems?
SYS64738
FS: HD2 PCI-x in a Magma 2-slot chassis with PCIe card Justin1524 Buy & Sell 5 11-29-2013 01:09 PM
FS: Magma PE6R4 chassis w/ cable and PCIe control card WildHoney Buy & Sell 1 10-06-2013 02:28 PM
Magma Chassis host card - which PCIe slot? Allan Speers Pro Tools TDM Systems (Mac) 2 09-07-2012 09:54 PM
PCI HD Accel cards, Magma pci chassis and newer PCIe Macs CD Productions Pro Tools TDM Systems (Mac) 8 10-07-2008 08:03 AM
Magma PE64R Chassis or upgrade PCI cards to PCIe crizdee Pro Tools TDM Systems (Mac) 9 01-27-2008 02:22 AM
