Old 12-01-2008, 05:11 PM
DigiTechSupt's Avatar
Exclamation Plug-in DLL is "not a valid Windows image"
This issue may come up when trying to install plug-ins on a VENUE D-Show system from a download. This only happens when the downloaded plug-in .ZIP files are decompressed with the Apple Archive Utility that comes with OS X Leopard (10.5.x).
This version of the Apple utility creates extra files which the VENUE D-Show software attempts to install as a separate plug-in and which produce the following error (here with SansAmp used as an example):
"The application or DLL C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins\._SansAmp PSA-1.dpm is not a valid Windows image. Please check this against your installation diskette."
Suggested workarounds:
  • de-compress using Stuffit Expander on Leopard
  • de-compress the files on a Windows system
By all accounts this used to work on Tiger, so you could also try to find a Mac running OS 10.4 as another alternative.
If the plug-ins are already installed they can also be manually uninstalled. Go to Options > Plug-ins and inspect the installed plug-in list in the right-hand column. Affected plug-ins will be listed twice. Click on each listing... one will display valid version info and the other will not. Right-click on the plug-in listing that has no version info and uninstall it.
Avid Audio Tech Support
Support FAQ
Old 08-24-2009, 01:44 PM
wopepro wopepro is offline
Thumbs up Re: Plug-in DLL is "not a valid Windows image"
As I also installed all the updates and plug-ins from my mac, I too got this error message. I easily could get rid of this by just deleting all of the hidden files beginning with "._" as these files are created and used from the mac's os. I used the search string "._*" to find all of these files and just deleted all of them.
Old 05-24-2010, 04:03 PM
!arecord! !arecord! is offline
Default Re: Plug-in DLL is "not a valid Windows image"
Thought I might add this to for mac users. To show the hidden files that start with "._" , type this in Terminal:
defaults write com.apple.finder AppleShowAllFiles TRUE
Then use this if you want to turn it off:
defaults write com.apple.finder AppleShowAllFiles FALSE
Find new house music and records
Old 05-25-2010, 08:30 AM
Mike Z's Avatar
Mike Z Mike Z is offline
just so everyone knows, this issue is resolved in 2.8.1 or higher. D-Show now ignores the "._" files.
-Mike
Avid Live Sound Support
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
Pro Tools (LE to 10) Crossgrade --"Unable to recognize disk image" Tellusall Telos macOS 0 06-19-2012 02:43 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
"no valid network adaptor is available for video satelite connections " message nachonieto Pro Tools TDM Systems (Win) 4 03-30-2009 04:51 PM
