bypassing preamps on mbox
Coudn't find any previous answers on this specifically- I'm planning on buying an mbox and building Allen's under $600 machine. Yet, I'd like to push the sound quality as far as I can with my small setup by getting a higher end preamp and converter. Is it possible to bypass the Mbox preamps or will they remain in the signal path and degrade the quality of the pro level equipment? (I'm not a sound engineer by any means so sorry if this is an obvious question)
Thanks for the input . |
Re: bypassing preamps on mbox
If you get a seperate set of pre's and an Analog to Digital converter with SPDIF outputs...you can bypass the pre's and the converters on the MBox entirely. (What I'd recommend if your looking to upgrade the MBox as far as possible without moving to a 002). If you simply wish to bypass the pre's and still hit the mbox' converters, you can use the return side of an insert cable to send an unbalanced signal straight to the converters of the MBox.
Cavell Studios |
Plug into the TRS inputs of the M-box to bypass the mic pres.
Hello Rod,
...and Welcome.. Quote:
If you are not satisfied, rent a couple of pre/AD boxes that will eventually fit your $$$ range, and compare your results. happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
I agree with Lemix, the M-box pres and converters are very nice, and you'll be spending at leadst 4x the cost of the M-box to get any significant improvement.
Thanks all for the input -(Sounds like I may be underestimating the pre's on the Mbox) - As far as a mic I'm leaning toward the AKG C-414B (mainly for vocals and acoustic guitar) -
Thanks again! |
A pair of 414's are it for me on acoustic gtrs, and an excellent choice for vocal mics.
bypassing mbox 3 preamps | Lonefse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-17-2011 05:21 PM |
Bypassing mbox preamps | brian4411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-02-2008 10:19 PM |
Bypassing mbox preamps | Denes Pagan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-19-2007 09:55 AM |
Bypassing mbox preamps | Denes Pagan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-19-2007 07:52 AM |
Bypassing MBox preamps - direct in | Ian-H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-25-2006 05:16 AM |
