Old 05-05-2021, 12:12 PM
darkwavo darkwavo is offline
Default Carbon with 500 rack- bypassing the preamps / connectivity
Hello all.
I’m planning on using Carbon with a 500 series rack of preamps, compressors and effects. It has XLR and TRS connectivity on back of the 500 rack.
I am wondering what the best way to connect this would be... through the DB25 with a DB25–>XLR snake?
Would this bypass the mic pre circuitry and just go line in?
Also , is it possible to make a hardware insert from one of these I/O connections and insert a hardware 500 compressor for example on a pro tools track with no hiccups or latency Issues?
Thanks !!
Old 05-05-2021, 01:53 PM
Default Re: Carbon with 500 rack- bypassing the preamps / connectivity
....through the DB25 with a DB25–>XLR snake? either works fine and most likely there's no difference.
...is it possible to make a hardware insert from one of these I/O connections and insert a hardware 500 compressor for example on a pro tools track with no hiccups or latency Issues? My opinion only; re latency, I can't answer, but I would expect some due to the round trip thru converters. My personal preference is to use hardware on the way INTO Pro Tools(to get the sonic flavor), but keep mixing all in the box
Old 05-05-2021, 02:33 PM
I thought I read somewhere that the DB25 bypassed the mic preamp section on the way in.
I might be wrong
Old 05-05-2021, 03:30 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Originally Posted by darkwavo View Post
Hello all.
Thanks !!
Hello,
Yes, you'll want to use DB25 cables to connect your outboard gear to the Line In and Line Out connections on the back panel. You can then connect any mic inputs to the XLR inputs. On the front panel, simply switch the channels between MIC and LINE input type depending on when you need line input vs mic inputs. If you want to bypass the gain on the Line inputs you can do that in Pro Tools > Hardware Setup > Line I/O. We made a number of improvements to automatic delay compensation for hardware inserts in Pro Tools with 2021.3, so it should be very solid now.
Hope that helps.
Kyle
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 05-05-2021, 08:23 PM
Originally Posted by Kyle Splittgerber View Post
Hello,
Hope that helps.
Kyle
Great, thank you Kyle.
What is the advantage of bypassing the gain on the line inputs ?
It that a cleaner line in to the converter section ?
And good news on the I/O delay compensation. I use the outs and ins all the time typically to create hardware efx sends/returns , parallel process , etc.
Thanks again !
Old 05-06-2021, 01:50 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Is it possible to use any of the physical outputs on Carbon as physical sends?
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 05-06-2021, 12:38 PM
Yes, it can function that way (just like with any interface in Pro Tools).
Kyle Splittgerber
Berkeley, CA
Old 05-07-2021, 11:58 PM
chrisdee's Avatar
So if am recording my vocal chain (mic-> pre -> comp) connected to one of the Carbon line inputs (for example line input 1) i can also route that signal to one of the outputs and send this to my external headphone amp?
Also wonder if my Omni has true bypass on the line inputs?
Old 05-06-2021, 12:35 PM
Thanks again !
Sure thing. Bypassing line input gain improves performance. See highlighted numbers in the attached.
Kyle Splittgerber
Berkeley, CA
Old 05-07-2021, 12:23 AM
Great!
Makes sense to hook it up to the DB25 and have all options at hand.
Nice design feature too (true bypass) for line inputs.
Cheers.
Bypassing the preamps stainless ICON & C|24 9 05-26-2007 05:19 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2007 09:55 AM
Bypassing mbox preamps Denes Pagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2007 07:52 AM
bypassing preamps on mbox Rod Elledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-30-2004 07:59 PM
bypassing 001 preamps djc8902 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-20-2004 08:24 PM
