Old 02-02-2011, 07:52 AM
Postman Postman is offline
Default Re: NuGen Audio's VisLM loudness meter
ATSC A85 loudness standard that is now law in US
It becomes a defacto law next year, and will not be enforced for a year after that. US congress essentially said that whatever ATSC recommends will be the law. That allows room for change. I am curous to see if the US will continue to have -24 LKFS/LUFS while the EU works with -23. That would be stupid, but it wouldn't surprise me.
Old 02-02-2011, 07:56 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
The US voltage difference to the UK has caused many probs over the pond, different frame rate headaches for you NTSC chaps (& chapesses) - be nice if we could agree on something
cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 02-02-2011, 07:57 AM
can it read files - or do you have to play your mix through?
AFAIK, it is realtime only.
Old 02-02-2011, 07:58 AM
I think we just did!!
Old 02-02-2011, 11:01 AM
s0und80y s0und80y is offline
Most specs are + or - 1 so it won't be a problem. as far as my ear goes -23 or -24 as barely noticeable
Been in the biz since 96
  #16
Old 02-02-2011, 06:44 PM
kd_special kd_special is offline
Im not 100% sure but I've been told in Canada there is no Law or laws yet. I am not sure if there are any in the plans either.
Perhaps some other Canucks could chime in.
Every show I have done has a Spec sheet which looks like its a photocopy of a Spec sheet from the seventies. As it talks about Beta SP tapes and rarely has specs for 5.1 material. At least no specs audio wise. Its always kind of a gamble
kd
  #17
Old 02-02-2011, 07:01 PM
tomlowd tomlowd is offline
Originally Posted by MIKEROPHONICS View Post
Hi Tom - dialnorm is dead. Sky specs will be LKFS -23 (new version about to be published soon) as per ploud's recommendation. So that will apply to Nat Geo in the UK too as they TX on that platform.
Yes I would trust them for a dolby E layback, just as I trust Neyrinck with his encode and decode. Good software is great!
cheers
thanks mike! i just did some reading and LKFS is in use in australia now too.... so, i'll give the v-meter a go! i really need something that can check files offline though. that's a very handy feature of the media meter
  #18
Old 02-02-2011, 09:12 PM
ILOVEPROTOOLS ILOVEPROTOOLS is offline
You should look into this one also:
http://www.vsonics.com/vmeters.php
I've seen an early version and it looks pretty good. Lots of flexibility, lots of meter types.
BTW, I don't think "dialog intelligence" is at all import anymore. It's day has past. Gating based on level, such as recommended in the EBU R128 document, IS important. Vmeters does not have it yet, nor do most others currently on the market, but the devoloper has indicated it is coming in an update. Vmeters seems to have 'most everything else. The version I saw matched LKFS readings exactly to my LM5D and LM100. I have not checked the latest version, though. I will soon.
ps, I haven't tried nugenaudio's, I just wanted to point out a new option
Thanks So much for this!!! I needed LKFS monitoring at home for cheap.. i was about to give in and get the DMM2. Woo Hoo!
Does anybody know if Disco changed their specs in regards to the DX intelligence and are going with LKFS? Or are planning to soon?
Oh and also I did want to say the DMM2 also has LEQ(m) for Movie trailers and is a breeze to use and I dont see that feature on either one of these meters. Unless i missed it.
slashasteriskmusic
  #19
Old 02-03-2011, 02:39 AM
NUGEN are going to do offline file metering like the dmm2
cheers
BAFTA member
IPS member
  #20
Old 02-03-2011, 07:00 AM
I just checked in with Jon at NuGen and to my chargrin, I hadn't noticed that there is an audiosuite version included as well - that can measure files instantaneously.
NuGen are also working on 1) new features 2) a batch processor & correction tool, which is in Beta - exciting times ahead for this plugin
The batch processor and correction tool will be on demo later in the month http://tech.ebu.ch/loudness11
cheers
cheers
BAFTA member
IPS member
HTML code is On
New Waves WLM Plus Loudness Meter nst7 Post - Surround - Video 28 01-18-2014 02:34 AM
WLM loudness meter, need help. nossnevs Post - Surround - Video 5 03-09-2012 01:56 AM
How to set my Loudness Meter.... kd_special Post - Surround - Video 13 02-08-2012 01:41 AM
Nugen VisLM Settings for Theatrical Commercial and DVD Napping Post - Surround - Video 10 01-22-2012 01:56 PM
New loudness meter TC LM5 nucelar Post - Surround - Video 6 01-24-2008 02:50 AM
