Old 09-21-2013, 09:09 PM
gamblor gamblor is offline
Default hd native and mbox pro on same computer?
can you run both on the same mac pro computer using PT 10?
or do i need a different version of 10 to run the mbox pro?
i don't have a console right now, but sometimes i want some monitor options for the occasional overdub, which is where the mbox pro would come in handy.
thanks...
Old 09-21-2013, 09:39 PM
nst7 nst7 is offline
Default Re: hd native and mbox pro on same computer?
I'm confused by what you want to do.
You can have both HD Native and an HD interface installed on the same computer as an Mbox Pro, but you can only use one or the other at a time.
I don't know why you'd want to overdub on an Mbox Pro if you have an HD interface available to do that on the same computer.
As far as monitoring, if you don't have monitor controller, the Mbox Pro can be switched into a standalone D/A converter mode, so you could go out of your HD interface digitally into the Mbox Pro and use the monitor section of the Mbox Pro.
If you could elaborate on what you want to do, that would help.
Old 09-21-2013, 10:29 PM
hmmm.
yeah, i guess i would like to use the mbox pro for monitor control/headphones.
i can have it operate standalone?
is that something i need to configure?
thanks for the help...
Old 09-21-2013, 10:31 PM
does the mbox require additional drivers or something?
i haven't used it in quite awhile, and never on this mac pro yet.
Old 09-21-2013, 11:18 PM
ok.
loaded mbox drivers.
got it to work using s/pdif.
now, can i use it in the same way using analog sources?
example, various outputs from 192 interface into mbox pro? to do hp mixes for artist.
i'll prob answer this myself at some point.
thanks for pointing me in right direction...
HD native card & TDM in same computer? BasketCase Pro Tools HDX & HD Native Systems (Mac) 1 02-04-2014 06:24 PM
about to upgrade to new computer, HD Native, PTHD 10...thoughts on build? jonathan jetter Pro Tools HDX & HD Native Systems (Win) 16 02-08-2012 11:36 AM
What make is computer keyboard in PT 9 Native Ad?? Armando Pro Tools HDX & HD Native Systems (Mac) 4 08-24-2011 07:45 AM
PTHD 9 native not being recognized after computer is shutdown nme1 macOS 3 03-24-2011 01:31 PM
computer for hd native grant howarth macOS 2 01-28-2011 01:26 PM
