Old 05-09-2010, 01:13 PM
zubel zubel is offline
Default problem whit rosetta and Protools interfaces
Hello to all!
The equipment that we have is;
MAC G5 QUAD PPC 4 procesadore to 2,5 GHz and 13 RAM's Gb.
Operating system Leopard MACOSX 10.5.8.
Protools 8.0.1 - HD3 Pci-express.
This one connected hereby;
Of the first trajeta (The Core) the digiink goes out up to the port of entry of the PRISM and of the exit and this to
Entry of the apogee rosetta 800.
Of the following Accel the digiink goes out at the entry of her 192IO.
The Word clock is realized of the this way;
The Teacher is firstly interface (PRISM) of this one goes out a bnc up to 192IO, which takes one "T" and of the exit of
This one "T" goes to other one "T" connected at ROSETTA'S entry, staying the free exit of this one "T" compensated with a Resistance of 75Ohm.
THE PROBLEM;
The HARDWARE SETUP detects three units. Without problem.
THE I/O SETUP detects three units and the income and exits (INPUTS AND OUTPUTS), the whole OK are.
If the meeting that I open is minor or equal to 24bits 48Khz everything works OK!!!!
IF THE SESSION IS MAJOR GIVE 24/48 (pej. 24BITS 96KHZ) the Rosseta does not change the clock (it does not notice PRISM)
The income and exits do not work. So it does not even change to 192Khz in the fontal of the interface.
This it is the problem.
MY QUESTION:
Can you help me? If instead of the rosseta tendria has one 192IO normal desaparaceria this problem?
Can it be for the firmware of the rosseta?. Rosetta is new. And till now only working with the PRISM and with
Everything was going perfectly.
They have spoken to me that the interfaces they have to be to 1x256 or slightly this way, when they told it to me I did not understand anything....
A greeting and been grateful, Asier.
Old 05-09-2010, 03:17 PM
musicman691 musicman691 is online now
Default Re: problem whit rosetta and Protools interfaces
Maybe if you posted in your native language someone might be able to help - hard to understand your question.
Jack
QAPLA!
Old 05-09-2010, 03:28 PM
Pardon, I am sorry.
I am going to try to write it well.
Excuses.
Thank you.
Old 05-09-2010, 03:52 PM
Hello to all!
I have 3 converters.
1-PRISM ADAXR8 (He behaves as a digidesign 192io.)
2-APOGEE ROSETTA 800 192K.
3-DIGIDESIGN 192 I/0.
I HAVE THEM CONNECTED OF THIS FORM:
OF THE CARD CORE PCI -e of the computer, the cable digilink comes at the entry of the PRISM.
Of the exit of the PRISM the cable digilink ROSETTA enters in.
Of the card ACCEL another cable digilink enters the DIGIDESIGN 192 IO.
MY PROBLEM IS THE FOLLOWING ONE:
ROSETTA ONLY WORKS WELL WHEN THE SESSION IS MINOR OR EQUAL GIVE 48K.
ROSETTA DOES NOT WORK IF I WANT TO DO A SESSION GIVE 96K or 192K.
THIS IS MY PROBLEM.
Thanks !!!!!
Old 05-09-2010, 03:53 PM
BaileyBass BaileyBass is offline
Originally Posted by zubel View Post
Pardon, I am sorry.
Excuses.
Thank you.
Zubel, your question is obvious if one takes the time to read it,
Read OG Killas post in this thread. I think this is your issue, or will lead you to it. SB
click this
or read this, from OG KILLA,
We had the same problem here when we first got the ADA8. A quick call to prism gave us the answer...
The "Loop Sync" on protools is ALWAYS at 441 or 48. It never does anything higher than that even though the interface is running at a higher sampling rate.
What you need to do is take the wordclock out of your ADA8 and run it to the Word clock in (not loop sync) of the 192. It's ok to have the Prism as the first interface... that's what we do here. We also have a second 192, for that, you connect the two 192s together with loop sync, but the ADA into the first 192 should be connected through the WC input NOT loop sync.
ProTools D24 whit DSP Farm run on 6.4.1 dgpedalboard Pro Tools TDM Systems (Mac) 8 01-27-2014 01:25 PM
problem whit artist control ozzomorales Artist Series 1 04-30-2012 09:49 PM
I need Help please!! problems whit pro tools 8 le gonzaurio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2011 07:21 PM
Help: problem whit quantize! Better choice for set up? nanetto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-23-2007 04:52 AM
Direct Connect whit Pt le 5.1 Skaberlakestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-23-2002 03:25 AM
