Old 11-13-2003, 07:45 PM
Bug0711 Bug0711 is offline
Default HELP... Audio Drive formatting problem
My System Drive is setup as: Partition / Basic / NTFS (which according to Digidesign is correct)
My Audio Drive is setup as: Simple / Dynamic / NTFS (which according to Digidesign is wrong)
I have no idea as to how or why they are setup this way. I have went ahead and wiped out all of the files on the Audio Drive and am stuck trying to figure out how to get it set correctly.
FYI:
2x 80gig Western Digital HD / Window XP Pro / Asus A7V600 / AMD 3000+/333 Barton / Digi002r
Any help would be a gas! -Thanks
-Brian "Bug" Gallagher
Heritage Guitar Endorsing Artist
www.mindspeedmusic.com
Old 11-13-2003, 08:12 PM
audiotracker audiotracker is offline
Default Re: HELP... Audio Drive formatting problem
I use the following script to set my hardrive to it's original factory settings(like I just bought it)..once run, all your partitions are deleted,so you have to format and re-create partitions on it. To make sure you are doing it to the right hardrive, unplug your system hardrive(after shutting down your computer)pop in a Windows 98 startup disc,boot up, then run the script at the A:\ prompt
A:\> debug
-f 220 L1000 0
-a cs:100
OFC2:0100 mov ax,301
OFC2:0103 mov bx,200
OFC2:0106 mov cx,1
OFC2:0109 mov dx,80
OFC2:010C int 13
OFC2:011E int 20
OFC2:0110 (hit enter)
-g (hit enter)
Program terminated normally
-q
A:\>
after the -a cs:100 you just type everything on the right handside...the mov ax,301 etc...i have used this many times and it works well. this script will turn your hard drive back to factory settings...
Hope this helps
Old 11-13-2003, 08:24 PM
well, more of an XP way is to click Start, right click on MyComputer, then Manage->Storage->DiskManagement. From there delete the existing partitions from the audio drive, repartition (not dynamic) and format.
Quad 2.5 G5, 4.5G RAM
Old 11-13-2003, 08:40 PM
Well, that was alot easier than I ever dreamed... I was afraid to mess with that stuff earlier.
It is formatting now.
Thanks for the reply.
Formatting external audio drive for MacBook Pro jacknprewitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2010 08:04 AM
Formatting an audio drive in a new imac g5 cyrus222 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-28-2006 12:44 PM
formatting an audio drive joshuah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-27-2005 06:48 PM
Need help formatting dedicated audio drive MadeByNick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-06-2003 12:15 AM
A general question on audio drive formatting tld Tips & Tricks 3 08-04-2000 11:08 AM
