Old 08-11-2022, 10:25 AM
johnbarnesiii johnbarnesiii is offline
Default Drums Playlists - Groups Not Working in Waveform Mode
Hi guys,
I’m in PT 12.5 on a Mac. I’m trying to do some drum comping. I have 4 playlists, different performances of the same song, trying to comp together the best parts of each take into one.
I have all drums into one group. When I’m in playlist mode, switching between each of the 4 playlists works well and when you switch from one playlist to another, it switches all drums accordingly.
However, when I go to ‘waveform’ mode, it stops working. Meaning, when I switch from one playlist to another, it only switches the one drum and leaves the other drums in the old playlist, even though all drums are selected and in group mode.
Any ideas why this is happening?
Old 08-11-2022, 01:46 PM
Default Re: Drums Playlists - Groups Not Working in Waveform Mode
Were the drum tracks grouped and groups turned on when the playlists were created?
Scott Gatteño
Old 08-11-2022, 02:08 PM
No. The drums were not grouped until after the playlists were already recorded.
Old 08-12-2022, 07:23 AM
Then they will never switch following groups...stupid, but that's how it is. If you click on the playlist arrow and look at the drop down menu of playlists on a track, there will be a number in parentheses after the playlist name. If you make the playlists in the same action, all those numbers will be the same and the playlists will follow groups. If those numbers don't match, they won't switch following groups. One quick workaround is to highlight all the tracks and use the Shift+<up or down arrows> to cycle through the groups. This will switch all the highlighted tracks in unison.
Hope that helps.
Scott Gatteño
Old 08-12-2022, 03:39 PM
Hope that helps.
Thank you! That’s a bummer it won’t work unless you record with groups already created first! I will try the workaround you suggested though. All the best.
Region Groups-->Clip Groups Import File Menu Not working minister Pro Tools 11 0 01-06-2014 11:23 AM
Playlists sometimes don't follow groups. WernerF Pro Tools 10 11 12-19-2013 10:17 AM
Region groups and playlists fm_xtk Pro Tools TDM Systems (Mac) 1 10-14-2009 02:50 PM
Playlists, Groups, and Import Session Data Bug wyman Pro Tools TDM Systems (Mac) 1 07-22-2009 03:40 PM
Playlists and groups in 5.1 texan Tips & Tricks 0 04-17-2001 06:17 PM
