LOOKING MacOS 10.13.0 High Sierra OS Installer
hi
IM looking for MacOS 10.13.0 High Sierra, or 10.13.1 OS Installer +++++++++not 10.13.6 trying to run ON 3.2 QUAD MID 2010 MACPRO5,1 WITH PTHD 2018.4 OR 12.8.3 CANT FIND ANY WHERE ty |
Re: LOOKING MacOS 10.13.0 High Sierra OS Installer
Older macOS installers can be retrieved from the app store using Safari:
https://support.apple.com/en-us/HT211683 Why do you need such an early revision of High Sierra may I ask? Jeff |
Hi jeff
that links only for os 10.13.6 need 10.13.0 to upgrade 10.13.2 for PT 2018.4 or 12.8.3 I even call apple no help.......there a few plug that wont fly, that I need like Trigger 2 - sooth 2 (failed to load not vaild 64 bit AAX plugin) thay told me to get High Sierra OS....... any help would be awesome with this been looking for weeks tryed to buy on ebay no luck thank you Richard |
^^ check your PM`s
Those older installers most likely will not mount.
Apple used to not issue/post older macOS installers but they reversed course because older installers (even saved away) stopped mounting and would come up as "corrupt". Most likely reason is an expired certificate. So then Apple made available repacked installers. So even if you get a 10.3.0 installer, it might not work. If that happens, you might try taking the computer offline and changing the date/time. Then, if your install is successful, set your time back to the correct one after installation.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I love that time-travel date change idea, very cool.
Also, I'm not sure what happened with the OP's 5,1 but there should also be a "Recovery Mode" available. Restarting with "Command-r" should give you the option to reinstall the system on the drive's main partition - although I'm not sure which OS you'd end up with. |
Also, what about going down to Sierra? 10.12? |
Mbox2 pro macOS High Sierra | cguerrero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-22-2020 06:13 PM |
Fast Track Pro on macOS High Sierra | meireles | FireWire & USB Audio Interfaces (Mac) | 14 | 04-21-2020 07:02 PM |
macOS High Sierra 10.13.5 - CPU overload | wildcoyotesmusic | Pro Tools 2018 | 8 | 10-17-2018 06:42 AM |
Installation Problem on macOS High Sierra 10.13.3 | yaokeji | Pro Tools | Intro Discussion | 1 | 06-16-2018 01:57 AM |
macOS High Sierra 10.13 not yet supported | Avid | Technical Alerts | 0 | 09-25-2017 11:29 AM |
