Folder Routing
Is there a way to make a track in pro tools automatically route to the Folder/Bus when you drop a track on it?
This should be a feature in pro tools already but I always have to route tracks to it. I didn't know if there was a way to setup a hotkey or some other way to do it. |
Re: Folder Routing
No
Re: Folder Routing
Yeah, I had been wondering the same.. I just keep a couple of different track with blanks in the folders o my template use the duplicate command to make sure new tracks are routed correctly with the folder.
It can catch you out big time, if you're not careful. I agree, that it should be a preference.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Re: Folder Routing
+1 - Would LOVE this option. I have encountered a total of zero situations where I would want a track within a routing folder to not be routed to that folder. At the very least, this should be a preference. It would be especially nice if when duplicating a track folder, if it created a new bus to route the tracks to. They could simply take some notes from how logic pro x works in this regard.
Re: Folder Routing
Only when creating a new Routing Folder by highlighting existing tracks and using the Move To New Folder command (cmd-opt-shift-N). Then you can check the small Route Tracks to New Folder checkbox. There's no way to do it with existing Routing Folders.
Scott Gatteño |
Routing Folder Inside Routine Folder - Solo Issue | John9281 | Pro Tools | 3 | 03-20-2022 10:43 PM |
Serious Routing Folder Bug! | DrewHarrison | Pro Tools 2020 | 8 | 07-21-2021 02:26 PM |
Routing folder issue | musicman691 | Pro Tools 2020 | 3 | 12-22-2020 02:00 PM |
Routing folder+VCA | mgoorevich | Post - Surround - Video | 12 | 09-30-2020 03:45 PM |
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus | XJENSEN | Pro Tools 2020 | 7 | 04-24-2020 07:29 AM |
