Old 05-31-2010, 01:49 PM
Musick_X Musick_X is offline
Default Arturia Analog Factory SE and Windows 7
I re-installed Pro Tools LE after a crash and went with Windows 7 64-bit. Downloaded all the newest updates and drivers. Everything installed and worked just fine until I tried to install Analog Factory SE from my ignition pack (pack 2 version 2.1). I followed the .PDF directions included and installed the DAE to: "C:/program files (x86)/common files/Digidesign/DAE/Plug-ins" when the installer asked where to install it.
AF stand-alone worked like a champ! First time I opened it it asked me to register, and so I did. However, when I open Pro Tools and the program is loading I get this message:
Pro Tools could not load the following plug-ins either because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged:
Analog Factory.dpm
Move these plug-ins to the "Plug-ins (Unused)" folder?
I tried to uninstall and then re-install to no avail. Same problem occurs every time. Any help with this one? Could be I'm just missing a simple thing.
Arturia Analog Factory and Pro Tools 8 Dizzi45Z Pro Tools TDM Systems (Mac) 21 05-03-2011 10:38 AM
Arturia Analog Factory SE Bob Coulter Pro Tools 9 8 11-07-2010 06:59 PM
Arturia Analog Factory and Pro Tools 7.4 kwswitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-16-2010 03:53 PM
arturia analog factory 2 stuey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-30-2010 04:40 PM
Arturia Analog Factory Question bmcoonan Virtual Instruments 1 05-28-2009 06:54 AM
