Niggling things
I'd quite like to do a thread of all the tinniest little things that niggle me on a daily basis.
This is one : why can I enter a value in the subcounter here... http://duc.avid.com/attachment.php?a...1&d=1643978435 but can't enter a value in the subcounter here...? http://duc.avid.com/attachment.php?a...1&d=1643978435 It defies logic. I have loads more of these kinds of things btw. |
Re: Niggling things
I don't know, but if you explain what you are trying to do, maybe someone has a suggestion
Re: Niggling things
I don't need any help. I'm just whinging. The two boxes should work the same way and they don't, it's as simple as that really.
Re: Niggling things
If you're looking for Logic, you've come to the wrong place.
I just want Avid to make a convenient way use all its transport and marker features with a laptop keyboard that you can do with a full-size keyboard. I know there are workarounds but they cost time compared to real numpad usage.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB Last edited by daeron80; 02-04-2022 at 12:19 PM. |
Re: Niggling things
I've gotten to the point where every time I come across a bug or weird behavior I start a case. It's the only reliable way to get a bug report or feature request recognized.
~Will |
Re: Niggling things
For Midnight --Seems fairly logical to me, since being able enter a value/s is function your only going to use in the editing process ,,, and the counter you can enter a value is at the top of the edit page. I see no logical reason to have that function duplicated on the transport simply adding unneeded extra code to an already complex code YMMV
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Re: Niggling things
@midnightrambler
this is not necessarily a solution to your issue, but... if you have a numeric keypad: use the "/" key to select start counter (repeat to cycle through start/end/length) use the "*" key to select main counter again, not a solution, but a reliable/predictable way to achieve the same goal.
Devin Emke Audio Post Production Saturday Night Live, NBC |
Re: Niggling things
Also it's not the main counter I want to edit, it's the subcounter. (If you want the reason, it's because when I'm doing tweaks, I normally get sent a list of mm:ss times referenced to the mix I've sent, rather than bars and beats, which they obviously won't know as they're only listening to the WAV) |
Re: Niggling things
Re: Niggling things
Need to know how to some things... | Antboogie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-15-2009 08:03 PM |
Need Help with Two Things...... | Kazawa Atoll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-27-2005 08:41 AM |
iMac G5 !!!good things and bad things!!! | Jervy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-28-2005 01:36 AM |
3 things I can't do in OSX | Richard Barrie | Pro Tools TDM Systems (Mac) | 6 | 06-28-2003 08:42 PM |
Will this fix things? | jdavis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-23-2001 08:18 PM |
