Old 07-22-2022, 02:37 PM
leopod leopod is offline
Default Avid S6 crash when unplugging usb iPhone or iPad
Can someone reproduce this crazy bug :
PTSession open and connected to S6.
iPad or iPhone gets unplugged from computer hosting protools.
S6 loses all faders, displays and transport. MasterModule still displays workstation as connected. WScontrol app still displays connection to S6. No physical button or fader on S6 responds. Fixed only by disconnecting/reconnecting Protools host in Settings/Workstations window of M40 Module.
Protools : 2022.5
WSControl : 2022.4.0.78
Eucon : 4.8.6.78
S6 M40 : 2022.4.0.78
MacPro 2019 / MacOS 10.15.7
ipad Air 2 : iOS 15.5
iPhone 13 pro : iOS 15.5
I see no connection between USB on the MacPro and Eucon functionality, but since we can reproduce this problem on 2 different workstations, with 2 different S6 M40, there just has to be some kind of conflict. Other USB device unplugging don't seem to create same problem (USB drives, keyboard, trackball, dongles, ilok etc.)
Old 07-22-2022, 03:57 PM
BScout BScout is offline
Default Re: Avid S6 crash when unplugging usb iPhone or iPad
When you plug in an iPhone or iPad, your networking adds the iPhone/iPad. Go to System Preferences > Networking and disable the iPhone/iPad from creating a network there (you might have to have them plugged in for that to appear.) Also, click the gear at the bottom of networking and put your S6 network port at the top of the service order.
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Old 07-22-2022, 04:23 PM
Thanks for the suggestions, they were totally relevant with this case. Unfortunately it didn't solve my problem
Catalina doesn't seem to offer USB networking for iDevices, as they don't appear in the SystemPreferences/Network, even if they are plugged in and computer considered as "Trusted" by the iDevice.
As for the order, we have Ethernet 1 who carries internet and LAN connections, while Ethernet 2 carries the S6 network alone. So they have to stay in that order for internet to work. The rest of networking options are "Off", including Wifi.
We might have to upgrade to Big Sur and maybe iDevice handling will be better handled. In the meantime i've sent a case to Avid with log files.
Edit : I did try placing Ethernet 2 in first position for troubleshooting purposes, and same problematic behaviour occured.
Old 07-23-2022, 12:17 PM
EddieJones's Avatar
I can nearly say for certain this is because OSX is changing something in the networking which disrupts the EUCON network.
Old 07-23-2022, 07:03 PM
LDS LDS is offline
Works fine with Catalina here - 10.15.7. Have you tried hitting the + button at the bottom of the list to see if there is a USB option waiting for you to add?
File Type: png Screen Shot 2022-07-24 at 11.31.12 am.png (15.0 KB, 0 views)
littledevilstudios.com.au
Pro Tools Ultimate 2022.7. OSX 12.5.1 HDN. DAD DX-32R. DADman 5.3.4.2. Mac Pro iMac Pro. 10 Core 3.0gHz. 64Gb. BM Decklink. Sync HD. Dolby Mastering Suite 3.7.2.
Old 07-28-2022, 08:35 AM
creativecontrol's Avatar
I took a look at this here as well (on 10.15.7 + 22.6 + 22.4). The behavior is identical to when I enable Wifi for the scenario when adding an Avid Control client (not wired) to aggregate with S6. When the network rejiggers, the desk goes dark and then restores the tracks which were previously there within a few seconds.
best,
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 07-28-2022, 10:07 AM
best,
Jeff
On our side, the track restore sometimes happens by itself, but most of the time we need to uninstantiate / reinstantiate the host on the M40 for it to repopulate the desk. What is troubling also is that the same behaviour happens randomly during the day, even with no iDevice unplugging involved. During a 10h shift it can happen 3-4 times and we're a little at loss to pinpoint the problem. I've logged a case in avid support center, as we are under a support plan, but I'm afraid this has more to do with MacOS's network handling conflicting with S6 protocols. I remain hopeful they can find a fix or workaround.
Control Protools on a PC with ipad or iphone? stevedresser83 Avid S1, S3, Dock and Control App 5 02-09-2021 06:47 AM
AmpliTube Brian May for Mac/PC, iPhone, iPad Now Available Peter - IK Multimedia Partner Announcements 0 08-22-2019 10:46 AM
11 ipad/iphone app bassmanjazz Eleven Rack 6 05-13-2011 10:33 AM
Max level Iphone and Ipad can handle Studio Studio Pro Tools TDM Systems (Mac) 2 10-20-2010 05:12 AM
Guitar fx on your iPhone/iTouch/iPad from IK! Dism Eleven Rack 28 09-28-2010 11:32 AM
