Old 06-20-2022, 09:28 PM
ubxf ubxf is offline
Default S6 with M1 mini
Hello,
Trying to upgrade PT with S6. Went from PT 2019.5 Catalina OS on a cheese grater working great with S6 and Xmon to M1 mini with PT 2022.5 working fine but can't connect with S6. Any advice would be greatly appreciated.
Old 06-21-2022, 04:36 AM
its2loud its2loud is offline
Default Re: S6 with M1 mini
Originally Posted by ubxf View Post
Hello,
With very little information you provided I would suggest the following…
1. Make sure you installed WS Control and it’s running
2. If your using two hardwired networks, make sure you’re choosing the correct network for the S6
3. If your S6 was setup with a static IP, you will most likely need to assign this IP address in your Mac Network settings.
Here’s a good resource
https://resources.avid.com/SupportFi...rking_2021.pdf
Old 06-21-2022, 04:45 AM
Thank you for your response. Yes the latest version of WS control is running.
The same ethernet cable (direct connection) that works with the old computer is moved to the mac mini and WS shows !
I think it was using DHCP with the old system. Does the S6 need an updated software or firmware?
Old 06-21-2022, 04:57 AM
You provided no version numbers so it’s hard to know if anything needs updating or flashing. Did you download the latest S6 software if you’re on a current S6 support plan?
More info here…
https://avid.secure.force.com/pkb/ar...vid-S6-Support
Old 06-21-2022, 05:00 AM
No the issue is that the S6 support plan stopped in 2020
Old 06-21-2022, 05:15 AM
The old working system had 2019 Versions of PT and S6. The new set up has latest PT 2022.5 and Eucon 2022.4 but S6 is still with the 2019 configuration
Old 06-21-2022, 08:33 AM
You shouldn’t have any issues running the newer Eucon or WS Control with any S6 software past 2018. You just won’t get the most advanced features new to the latest release of Pro Tools. I suspect the issue is with your network. If you’re running S6 software older than 2018 then you’ll most likely need to update.
I suggest you have a read and check your MTM network settings.
https://avid.secure.force.com/pkb/ar...1-to-Static-IP
Old 06-21-2022, 10:44 AM
Thank you for your help, i'll look into it deeper
Old 06-21-2022, 01:43 PM
creativecontrol's Avatar
Did you use migration assistant to transfer to this new machine? If so, try changing your computer name under System Preferences > Sharing.
Make sure you have exactly the same version of WSControl and Master Module software running. Here's the current EUCON compatibility info:
https://avid.secure.force.com/pkb/ar...-Compatibility
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-21-2022, 03:40 PM
Thanks Jeff, i didn't use migration assistant. The new mac has a clean install of everything.WScontrol on the new machine is 2022.4.0.78
Could WScontrol 19.5.0.514 with works on the old machine be installed on the new machine ?
Mbox Mini (3rd gen) not connecting in High Sierra on old Mac Mini or new iMac Hoevelmann FireWire & USB Audio Interfaces (Mac) 0 04-26-2018 09:49 AM
Mac Pro 12Core vs Mac Mini 4Core.. Mac Mini wins Venshield General Discussion 12 12-06-2017 07:32 PM
FS: Apple Mac mini 2012 quad i7 2.6 in Sonnet XMAC MINI SERVER rack Jamie Mac Buy & Sell 1 07-02-2017 11:50 AM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 12:58 PM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
