Old 04-28-2010, 04:56 AM
bendybones bendybones is offline
Default using 003 Rack (+) with other DAWs
Hi All,
Someone in the HD forum mentioned that it is possible to use the 003 with other DAWs "via CAD".
I've tried to find info on this CAD option but cannot.
Can anyone give me some more info?
I would ideally like to use it with Logic (and maybe Ableton Live)
Thanks
Old 04-28-2010, 06:31 AM
se.audio's Avatar
se.audio se.audio is offline
Default Re: using 003 Rack (+) with other DAWs
CAD = Core Audio Drivers
It's usually installed at the same time as protools, but if you really don't want to install PT, I'm pretty sure you can choose to only install core audio from the installer. When that's done, start up Logic (or whatever else you want to use), go to the preferences, and choose your 003R+ from the devices available. this should start up the Core Audio program, and you're sweet to go.
It definitely works (i've done it many times), so don't give up on it if you can't find the right option or preferences straight away...
se.audio
Reaper as second DAWS DMB13KOS General Discussion 12 03-05-2014 04:58 PM
About SSDs in DAWs Sir Les 2 General Discussion 27 01-18-2014 11:13 AM
002 as controller for non PT DAWs? rhythmtechnologies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2010 07:01 AM
Can Eleven Rack be used with other DAWs (Digital Performer eg.)? hwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-02-2009 01:08 PM
Other DAWs... trkkazulu General Discussion 1 01-25-2002 05:56 AM
