Old 06-02-2009, 02:35 AM
nathanh26 nathanh26 is offline
Default Buffer size problems(too little then too much) during recording
I have an mbox pro tools 8 running on windows xp service pack3
Whenever i record, error(-9092) pops up, it tells me to increase H/W buffer size. The error message pops up at inconsistent times, sometimes 3 mins into recording or sometimes 1min.
The error message says to increase buffer size but when i do, error (-9129) tells me to reduce buffer size. This problem can happen when i dont play anything at ALL.
Ive tried all of the recommended ways to fix it and its been a year now and the bugfix for protools 8 didn't eliminate the problem.
I also know my computer is powerful enough to run pro tools.
It may be something in the background stuffing up when i record, but i have already looked thoroughly looked through the processes going on.
Please help out
Old 06-02-2009, 03:02 AM
Steevp Steevp is offline
Default Re: Buffer size problems(too little then too much) during recording
Your best bet is to post a sandra report using the software found here:
www.sisoftware.co.uk
Then users here will know what's in your system and will be able to point you in the right direction.
For me personally sorting out my RAM timings was the key to a stable system, and once again the sandra software helped me diagnose the problem.
www.Krankschaft.com
Windows7 64bit, RME UCX, Asus Z97-P, i7-4790K@4.00Ghz, 32GB Ballistix Ram, Console 1, Unity Audio Rocks, RME UCX.
Old 06-02-2009, 09:19 AM
sw rec sw rec is offline
"I also know my computer is powerful enough to run pro tools."
Possibly so, but the most "powerful" PC in the world won't run Pro Tools reliably if you don't follow Digi's recommendations where setup is concerned. The first thing we tend to ask on here....are you using a QUALIFIED, dedicated audio drive? This is critical, and the most overlooked item on the DUC........
low latency recording vs low hardware buffer size recording chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-27-2009 06:49 AM
H/W Buffer Size Problems soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 12-19-2006 04:11 AM
"H/W buffer size" pop-up problems mickj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-15-2004 08:39 AM
H/W Buffer size problems... Stingray74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2004 01:06 AM
BUFFER SIZE PROBLEMS... Renan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-04-2004 01:32 PM
