#21
Re: 2022.7 Custom Shuttle Lock Broken
Same problem here and no apparent conflicts. This looks to be a common issue, already covered in this thread:
https://duc.avid.com/showthread.php?t=420433 I submitted a support ticket a while back but the support personnel closed the case because I had a 'workaround' in place (ie. reverting to a prior version of the software.). |
#23
Thanks very much.
#24
Re: Custom Shuttle Lock Speed
No conflicts. In fact, I hear a slight glitch CTRL+9.
#25
I’m still having this issue on 2022.7 with IOS12.4.
I originally reported this to Avid on June 1st along with the “Import Session Data/Main Playlist Options” default issue which has subsequently been fixed. I have provided many screen shots and videos as requested by Avid and have heard nothing for over 3 weeks since a case number was issued on July 14. Sent from my iPhone using Tapatalk |
#26
Same here, just tested and still find it's stuck at 800%. I've got an open support ticket, have updated them on that. Real shame, as some of the other bug fixes/GUI stuff is nice, 2022.4 is my only option for my current workflow but that causes some issues with Soundflow. The fact that there's someone without the issue does suggest there's some config we're all sharing that's causing the problem at least
#27
Re: Custom Shuttle Lock Speed broken in 2022.5 [PT-290238]
Fixed in 2022.9.
Fixed an issue with Custom Shuttle Lock Speed in Pro Tools Studio (PT-290238)
• linkedin •
#28
What I've found on my rig (PTS 2022.6, MP 5,1, macOS 10.14.6) is that while Custom Shuttle Speed is supposed to be a system setting, it seems to work as a session setting, meaning it has to be changed for each session. I work from a template for these kinds of sessions, and although the template has been set to 175%, each new session defaults to 800%.
For those of you reporting it "not working" in versions 2022.x - 2022.7, have you been checking session-by-session? In other words, does it work correctly after being reset each session? I'll install 2022.9 soonish. Hoping the fix addresses my findings.
Bob Without a song The day would never end |
#29
So far so good in 2022.9. Thanks jeffro and team. |
#30
I also need this feature working! I have Studio 2022.5.
How to use shuttle lock without a numeric keypad? | leod608 | Pro Tools 11 | 0 | 06-06-2017 09:40 PM |
Custom Shuttle Lock Speed feature removed? | daeron80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-17-2010 09:29 AM |
custom shuttle on macpro | Lonny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-10-2009 12:44 PM |
Shuttle lock preview | Chuck Johnson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-16-2004 10:53 AM |
tempo query / custom shuttle lock speed | privateIQ | Pro Tools TDM Systems (Mac) | 0 | 11-03-2003 06:01 PM |
