Old 02-15-2000, 09:02 AM
quisco quisco is offline
Default Clip problem, please help!!
I´m using the Digi 001 from two weeks ago and the last two days I´v found a problem, while I´m playing or recording suddenly , each 6 or 7 minutes, sounds a strong distortioned clip who had no relation with a peak track. It doesn´t appears in the same timeline.
I´m not realy know what´s happened.
Could be damaged the pci Card.
I need help!!!!!
Thanks in advance
(Sorry for my English)
Old 02-15-2000, 09:40 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default Re: Clip problem, please help!!
Be sure to check in the 'Session Setup Window', that sync is set to 'internal'...
That's all I can think of right now...
Arno Peeters
Tape TV Productions
Old 02-22-2000, 07:35 AM
DanXx DanXx is offline
Dear quisco,
I use a G4/sawtooth 400 Mhz with 256 Mb RAM and recently I have exactly the same problem:
a loud digital "tick" followed by complete or partial silence of the tracks. The tracks do show metering, but they produce no sound anymore. Closing the session and opening again helps for about 5 minutes, but then the problem appears again (This tick can really ruin your expensive monitorspeakers!!!).
I don't seem to do anything special. I have used a lot of plugins and tracks before, but the only thing i could possibly get was a DAE error, but this is different!
Ofcourse I tried reinstalling Pro Tools and running it with a minimum set of extensions but nothing helped.
I searched the digidesign site thoroughly but not a word about it. I wish someone from Digidesign reads this and has an answer to our problem!!
Greets, Dan.
Old 02-22-2000, 05:02 PM
Dear DanXx
Finally I´ve found a solution at this problem . I´ve tested the loud clip only appears when I attached an external scsi Zip drive to the scsi port of my G3 266/190 beige Os 9.
What kind of gear do you use?
Have you installed an external drive?
Are you using a removal unit?
Thanks.
quisco
Old 02-23-2000, 03:45 PM
[email protected] SPAREMAN@AIRMAIL.NET is offline
yo danxx, i have the same exact problem. i thought my amp shut down in my monitors... i cac reboot and all is well for a minute then...pop... no more sound, just meters and transport playing. the only luck ive had is removing plugins. this seems to fix it. but you are right, we should get the error window. i wish digi would answer this. by the way i only have an internal zip, which i dont use. my system is a B&WG3/300.
bc
Old 02-24-2000, 06:35 AM
Hi all,
Thanks for the response.
My stuff:
400 Mhz sawtooth (AGP graphics)
256 Mb RAM
zipdrive (but this is standard on sawtooth)
Adaptec 2904 SCSI card (narrow)
I just tried running my computer with a MINIMUM set of extensions (even less than Mac OS base!), turning off Adaptec SCSI extension and the drivers for my Zip (amongst a lot of other things) but the problem stays the same!
I think it has something to do with the RTAS plugins, that they're buggy. Digidesign should take a look at it. And if it's hard for them to track (because of unpredictability) I am willing to give my "problem"-session to them, because with this one, it ALWAYS happens.
I even copied the exact line-up of plugins (and their presets) to another session and I got exactly the same problem.
I think I tried everything! Now I'm almost going to phsically remove my SCSI card... but maybe that's a bit overdone...
Digidesign, help!
Greets, Dan.
Old 02-24-2000, 06:39 AM
Hi all,
BTW: I forgot to tell that I record my audio on the internal ATA 66 drive (Digidesign approves of this).
My Adaptec 2904 narrow-SCSI interface is only for burning CD's.
Greets, Dan.
Old 02-28-2000, 05:36 AM
Frank S Frank S is offline
I had the same problem this weekend, and found that removing plug-ins also seemed to help the problem. Bussing a submix of three or four tracks to a stereo aux track really seemed to be the culprit to me, whenever I removed the plug-in (in this case Waves TrueVerb), or deleted the aux channel altogether - no problem on playback. I got both types of problems - loud clipped distorted signals, followed by/alternating with zero audio on playback, with all meters showing signals. Any other ideas out there?
Frank S
[email protected]
Old 02-28-2000, 07:52 AM
DigiTechSupt's Avatar
Frank gave you a good clue for narrowing down this or any problem. You gotta break it down.
* trash the digisetup file as well as the DAE prefs folder and the waves preferences (located in the system folder/preferences folder). Restart and try the session again. did it fix it? If not -
Make a copy of the session and then "working from the copy" take the plugings off of the tracks. Start with waves and go from there. Try it after you take the plugins out and see if the problem persists. This is only to see if we can track down the culprit.
If you want to do this quicky then just go to DAE folder/plugins folder and take out all the plugins except for the 16 or 24 bit optimized mixer plugin and also leave the waveshell. Relaunch pro tools and open the COPY of the session and see if the problem persists. If it does then quit PT and go back to DAE folder and take out the waveshell and relaunch the session. This time there will be no plugins. Did the problem go away?
B Carter
Digidesign
Avid Audio Tech Support
Support FAQ
Old 03-07-2000, 04:48 AM
Thanks B Carter for your reply and interest in this topic!
Sorry for my late reaction but here it comes:
- I tried trashing the digisetup file and the DAE prefs (I don't use Waves plugins) but it didn't help.
- By taking the plugins out one by one I quickly had good results: the problem stopped as soon as the processorload dropped significantly (by taking out a D-Verb for example). So the problem seems to have a relation with processorload.
- When I took out all the plugins from the DAE folder (I don't have 16 and 24-bit optimized mixer plugins, I use PT LE) the problem didn't appear either. So this problem has to do with the plugins.
But last night I was working on a session when a 1-band EQ started to behave a little strange: It randomly gave large boosts in the lower frequencies. And then I remembered that my "clicking"-problems also started with something similar (but that time with a 4-band EQ). So could it be the EQ's?
That's what I have for now.. I hope you guys can come up with a solution for this in the near future.
Greets! Dan.
Clip editing problem ! stratevcaster Pro Tools 10 14 02-26-2013 09:03 PM
Audio Clip Display Problem Daryl Hughes Pro Tools 10 2 01-06-2013 03:07 PM
clip groups question/problem? capt kirk Pro Tools 10 1 11-01-2012 02:36 PM
ProTools 10 + plugin clip view problem thundervip macOS 2 12-06-2011 06:56 AM
problem with 192 clip bonfi64 Pro Tools TDM Systems (Mac) 0 02-28-2011 05:59 PM
