Old 12-06-2011, 06:27 AM
thundervip thundervip is offline
Default ProTools 10 + plugin clip view problem
Sorry if this has been answered before, I have tried searching and using google with no luck (and I am new to this forum so not sure if this is the correct place to post)
When using the PT9 HD set up at uni, if a plugin's output clips (for example the output on an eq clips) it turns the insert on the mixer red - and I cant figure out how to enable this in PT 10 (not HD) on OSX 10.6.
In the reference manual it says to go to > preferences > Display > Select clip mode
In my preferences under the metres section within display, the clip indication is set to infinite but still no red insert within the mixer even when I purposely drive the output into clipping within a plug in.
Any ideas how I get this to display?
Old 12-06-2011, 06:49 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: ProTools 10 + plugin clip view problem
It's an HD only feature
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 12-06-2011, 06:56 AM
Ah ok, thanks
How do I stop playlist view destroying clip groups? clutch Post - Surround - Video 3 11-14-2013 08:27 AM
Protools 9 - Plugin Problem nikoli92 macOS 3 01-10-2012 10:26 AM
Strange Plugin view problem ufostraker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-23-2008 12:03 AM
Protools Plugin Problem doubledave22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-07-2006 08:08 AM
Plugin Problem in Protools LE... Icemaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-15-2004 10:15 PM
