My question is how room size affects my mix.
I recently mixed a documentary for TV in a studio on nearfield speakers that was approximately 4.5m x 4.5m squarish. It was then played in a large meeting room that would seat approximately 75 people with very high ceilings. On playback I found the music beds and sound effects were much quieter than when I mixed it and I’m just trying to work out if that’s an issue with the PA system or just the physics of the room. I know that mixes for TV and mixes for cinema should be done in different size rooms and at different levels and I wondered if that’s what’s going on here. Thanks
Scott Auckland New Zealand PT2024.10 Focusright RedNET 8Pre, RedNET R1 Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit MacBook Pro 2015, 16GB Ram, Monterey 12.7.6 |
Put your room dimensions into this and see what is happening in your mix room:
http://www.mcsquared.com/modecalc.htm That is where the Mix issues are.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
there's a couple of possible factors - is your mix room calibrated to proper levels and generally the frequency response and RT? is the listening room calibrated as well?
it's possible the levels in the mix room were higher which meant you may have mixed things quieter. or the listening room system cannot produce enough levels with conforming audio sources. cross-checking with calibration audio and/or reference audio will help. a square room can be less than ideal - but sometimes it can assist especially with smaller or lower powered monitoring as the "room gain" and "LF reinforcement" can actually help - however - you need to test to determine if the effects are beneficial or not. |
Could be several causes as mentioned.
Was this a stereo mix or 5.1? What is the playback system? Speakers / b-chain specifically. "Meeting room" to me could mean soffit mounted loudspeakers, small recessed ceiling speakers, or a portable PA setup. Have you done it before or is this the first time listening in this room?
~Will |
![]() Quote:
Having said that, despite proportions, you should check if your room acoustics have minimum specs and balance frequency wise, reverb time etc. Also, mixing SPL also affects your perception of the mix. For rooms of the size you´ve mentioned, I personally would mix between 73 and 79 SPL C weighted/slow. Adjust the SPL on each of your monitors and stick with it at the same level during the mix.
Regards, Paulo M MAC Studio M1 Max_64 GB RAM_1TB SSD_MAC OS Sonoma 14.5. Protools Studio 2024.3, Logic Pro 11. MOTU M64 and Merging Technologies Sphynx2 converters. |
Minimum Size Room for Listening | Nathan W. | Post - Surround - Video | 3 | 08-29-2017 06:26 AM |
Loudness and room-size was: TV-Mix for Theatre | Frank Kruse | Post - Surround - Video | 94 | 01-09-2011 05:15 PM |
Solo in control room affects headphones mix.. | Jj Cichon | ICON & C|24 | 3 | 12-28-2007 02:30 AM |
drum recording room size | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-11-2003 02:45 PM |
Control Room Size? | seeds | Tips & Tricks | 24 | 07-06-2002 03:19 PM |
