Hi guys,
My MTRX Studio doesn't power on. I can see that there are some energy coming through, the leds inside are on and flashing, but in the front, nothing happens. I tried to hold the power button for multiple different times... nothing. Also I read the manual and tried to restore the interface by pressing the small button on the the back of the interface, following all the instructions, but nothing happened as well. In the DADman, the interface shows offline, without any connection. Is there any other option to try to revive the interface or just sending back for support? Thx |
![]() Quote:
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Greetings,
Can you see or connect to the device in DADman via Settings > Device List > IP ? If so, if you right click on the IP address what do you see? Jeff |
![]() Quote:
No, It does not appear into DADman. "DADman cannot find this unit:" I also uploaded a video showing what's going on. Video: |
DADman cannot find this unit would only present if DADman is trying to restore settings and profiles from an existing device.
(A) Do you have network communication / link happening from MTRX ST to the workstation. On the Mac > System Preferences > Network. (B) If you open DADman and go to Settings > Device List > can you see (refresh) any MTRX devices on the network listed by IP address? (C) If you do see an IP address > can you right-click and toggle into application mode? Jeff |
![]() Quote:
The MTRX is "dead". It simply doesn't appear anywhere. The lights inside are on, the ethernet plug is flashing, but at the front is all black and offline. |
Certainly feel free to engage support. I've seen this behavior before and recovered units that appeared lost at sea. If you would like to try some other tests PM me.
best, Jeff |
![]() Quote:
Customer service is already handling now. Will dispatch to repair. Cheers |
I'm having a similar issue but the power button is flickering and I can hear the unit clicking internally. It seems there is a power issue related to outlets in this new studio we moved into. The Audient ASP880 is reacting the same way. Is there a particular tolerance that equipment like this must have in the power supplied or it will not function? The other gear in the setup powers on and seems to work ok but these two units (that worked fine in the previous location) are not happy.
Put them on any voltage regulation UPS.
You'll be able to see what the wall is supplying and the UPS will boost (or cut) for voltage irregularities. They are pretty cheap. They CyberPower ones are pretty easy to go with from Amazon. (you are looking for the feature of "AVR" = automatic voltage regulation) We had one grid (literally 2 blocks) of the city power supply that was consistently varying out of standard and tripping up gear at a studio. Had to call the city and demonstrate the issue and they were able to fix it. But the swing was so wild that even AVR couldn't manage it (but we could see it on the readout which is how we found the problem.) That was with a Furman unit with AVR (which was less capable than the the Cyberpower ones today.) APC and Tripplite units have it too (the spec sheets will tell you how much variance they can deal with.)
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.2 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Difference between MTRX and MTRX Studio? | snowplaysmusic | Pro Tools | MTRX & MTRX Studio | 4 | 11-26-2022 08:48 AM |
MTRX MTRX Studio Forum Section? | off the wall | Pro Tools | MTRX & MTRX Studio | 2 | 05-08-2022 03:20 PM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
MTRX Studio doesn't show up in Dante | Erdem Yetim | Pro Tools | MTRX & MTRX Studio | 5 | 07-13-2021 02:51 PM |
MTRX Studio doesn't show up in Dante | Cheesehead | Pro Tools | MTRX & MTRX Studio | 5 | 12-02-2020 08:02 PM |
