MIDI Tracks have all died and gone Black\'n\'White!
Hi all,
Not sure what I've done here... All the MIDI tracks from within one of my sessions have suddenly switched to black and white (ie. the notes are no longer coloured). They won't playback, nor register new MIDI input despite checking the MIDI Input option is checked. My other sessions appear ok, so I presume its something I've changed with this particular session. It's probably something very simple. Any ideas? Phil
SoundPunk | Pro Tools Tips & Tricks |
Re: MIDI Tracks have all died and gone Black\'n\'White!
Phil
look to see if the midi input is set to "none" if so re-select the input. Also, if your using different midi ports make sure that your OMS driver has loaded because this will cause this too. CR |
Many thanks CR!
All 50 MIDI tracks had their inputs switched to NONE! Very strange. I hadn't even been touching the MIDI side of the session, just the audio, and had suffered a couple of crashes while calling up audiosuite plugs. No idea why??? Anyhow, I guess this may have corrupted the MIDI inputs. Anyone else suddenly lost their MIDI input assignments? I know it can happen if you alter your OMS Studio Set-up to something different from your session. Thanks again, Phil [img]images/icons/grin.gif[/img]
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
Midi Tracks - how do I record enable mutliple midi tracks? | ram1500 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-22-2007 04:32 AM |
Set up midi tracks and playing back midi tracks | RUNDMOD4MUSIC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-04-2005 03:22 AM |
Bouncing Midi Tracks to Audio Tracks ...Latency? | kirk95 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-27-2004 06:54 AM |
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2000 08:40 AM |
