Latest OS for the Digi 001?
Im running Pro Tools digi001
vLE 5.0.1 on a MAC G4 using OS 9.1 what Pro Tools OS can i upgrade to and what would be the benifits? Id like to use Rewire is that a plug in that will only run in the new PT os ? what other plug ins are like that ?
ΩSQUALΩ |
Re: Latest OS for the Digi 001?
we run an 001 ona dual 1Ghz G-4 Quicksilver/OS9.2.2/PTle5.2.1. rock solid stable, high track/plugin count.
I also have an 001 and wanted to use Rewire, so went up to PT 6.2.2 and OSX 10.3.1 and it works fine.
International Award Winning Arabic Fusion www.ajmusiconline.com --------------- 2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8 3xVisionDaw,NI Komplete,Yamaha 01V/96 |
I also run the 001 with PT 6.2.2 with OS 10.3.2
Works fine for me! Rewire compatible! |
Did you guys step up to panther from Jagquar? If so, is it better or worse? Still sitting on the fence.
I upgraded from 9.2.
If you have not yet used Reason/Rewire, jump of the fence and upgrade. It is fantasmical!
- Proxy
G4 dual 1ghz QS (1.5gig RAM) / OSX v10.3.9 / HD4 / AD8K / PT v6.9 |
I had upgraded from Jaguar to Panther when I still had my 001 and it definitely got rid of the sluggish issues. I had never tested my track count cause it was pretty pointless since I was planning on upgrading my processor-- but at 400MHz the switch to Panther actually made PT6 more usable (though still painful until I upgraded the porcessor)-- before that (with Jaguar) I had almost given up on it and went back to 9.
I also crashed out of PT and received fewer errors (if any) than any previous PT6 version (using 6.2.2). Your mileage may vary. I've heard people say that they get a couple fewer tracks-- not sure if there's any difference from Jag to Panther, but from PT5 to 6 there definitely was a decrease. Personally, for me, the added creativity and experimentation that PT6 allows is worth a few tracks. At least until I can save up enough $$$ for the third rev G5/6's in a year or so. --- c
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Panther is SO sweet for both Pt and Logic.
Mbox and Digi 001 rocking....
its 12:30 in the morning ... are you going to bed? G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43 |
Digi 003 via Thunderbolt on latest iMac | SP4C3M4N | FireWire & USB Audio Interfaces (Mac) | 2 | 08-12-2013 02:24 AM |
BSOD with latest Digi 002/003 drivers | colourednoise | Digidesign Hardware & Software | 0 | 07-08-2013 09:55 AM |
Got Digi 002, want latest software | sneakyimp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-21-2011 05:28 PM |
latest Pro Tools version for Digi 001 | confusedhelp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-25-2006 07:07 AM |
Latest Digi 002 Model Number (is mine the latest?) | JoyMODE101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-28-2005 08:05 AM |
