Shortcut for Region Window Open/Close?
Is there any keyboard shortcut for open/close the region window/sidebar? Thanks, Daniel |
Re: Shortcut for Region Window Open/Close?
Not exactly, but you can save/recall window layouts (I forget the exact nomenclature). I usually have a couple of different window layout views that are associated with memories. One of those is the widest edit window I can make. By recalling a memory, I can instantly change the view.
Ahh, good thinking I´ll try it today, thanks! |
You can even tie a Window Config to a Memory Selection (In the Memory Locations window). This way you can set up Zoom settings, Track Show/Hide, Track Heights, etc as well as whether or not the Region Bin window, or any other window is open. Great for switching bet/ DX mix and Sound Edit in the same session.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
+1 ministe part of my workflow.
You can make some shortcuts with OS X Leopard (I think it works with SL too).
You have to put the name exactly is writen in Pro tools menu title. If you go to View > Other displays > you can see that no shortcut is added to Universe, Track List, Regions List and Midi Editor. Now go to System Preferences -> keyboard & mouse -> Keyboard shorcuts, at the bottom click the plus signal and add a shortcut. ex: Application (choose) Pro Tools HD Menu Title - Regions List Keyboar Shortcut - Alt, Shift, Command, L I don't think it work with all menu titles that dont have any shortcut in Pro Tools, but for regions List and track list, universe it works. : ) Regards,
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
Not really a short cut but you can open and close the region bin on the right and the track view on the left by hovering over the line that borders them and double clicking.
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
This is brilliant! also did contol option command I for I/O...
Shortcut for close plugin window | José Luis Díaz | Tips & Tricks | 11 | 02-02-2018 08:06 AM |
Keyboard shortcut to close the AudioSuite Window? | dversion | Pro Tools TDM Systems (Mac) | 2 | 10-16-2005 08:27 PM |
keyboard shortcut to close plugin window? | ratter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-29-2004 07:37 PM |
close audiosuite window shortcut? | lancebrwn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-28-2004 12:13 AM |
close audiosuite window shortcut? | lancebrwn | Pro Tools TDM Systems (Mac) | 0 | 06-27-2004 01:47 PM |
