Old 11-21-2007, 07:30 PM
832 M 832 M is offline
Default 002R isn\'t starting up properly...won\'t communicate w/mac
Hello,
I just upgraded to LE 7.4. I also just downloaded 10.4.11 Tiger. The first time I launched, everything was fine. I pulled up a session and began playback. About 1 minute into the song, the hardware suddenly loses communication with the software. After quitting pro tools, I powered down the 002, and then powered it back on. It usually clicks 3 times, and then the 44.1 LED turns on. This isn't happening. I tried powering down the computer, and unplugging/re-plugging the fire wire cable. No change. It seems that the hardware isn't starting up properly. I can't get the box to communicate.
I did a search and found info on the power harness issue. Anyone with experience think that this is what the problem is? I am using a mac pro dual 2.66.
Thanks
M
Old 11-21-2007, 08:13 PM
OddsAre OddsAre is offline
Default Re: 002R isn\'t starting up properly...won\'t communicate w/mac
If you aren't plugged into anything except power, and the relays don't click 3 times when you power it on then it def sounds like a hardware issue, and most people will say, "Yeah it's probably the power harness." Contact Digi about it.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 11-21-2007, 08:40 PM
Thanks
It's strange. I can get it to work if I let it sit for about an hour. However, it loses communication with the software minutes after the session has started. Is this common with a hardware failure? (works, doesn't work, etc.)
M
Old 11-21-2007, 08:48 PM
note: I am knocking on every piece of wood within arms distance... I haven't had a hardware failure yet, but it seems that if your 002R is working periodically and being sketchy, its more likely a hardware issue than software. Although 10.4.11 isn't officially supported by Digi. 10.4.9 is as high as they officially support. Not to sound like a broken record on every one of these posts tonight, but have you downloaded the Pre-Binding Script?
http://www.paceap.com/prebind_script.dmg
May not help but worth a try.
Old 11-21-2007, 08:54 PM
The prebinding download said something to the effect of: Pre binding doesn't need repair. I think this thing is kaput.
Is there a hardware exchange between the 002 and 003? I was looking on the digidesign site and couldn't see it listed.
thanks
M
Old 11-21-2007, 09:10 PM
best bet is to contact Digi directly. If it the harness its gonna be cheaper then swapping up to the 003, and frankly other than word clock and an extra headphone jack....... well you get the picture.
Old 11-21-2007, 09:25 PM
......Sucks.
Looks like I won't be getting much done until Monday. Let's eat some bird.
M
C|24 Can't Properly Communicate with PowerMac G5 Groove Agent ICON & C|24 6 03-20-2009 12:01 PM
002R can't communicate....Help Strut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-24-2005 04:43 AM
update firmware = Can't communicate with digi 002r BrettB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-31-2004 09:42 AM
002R doesn't communicate with G4 djwilmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2003 06:26 PM
Question for Digi Tech Support and others: PCI bus too busy to communicate properly.. antnyzman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2002 11:17 AM
