Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
  #21
Old 04-26-2021, 01:45 AM
Farhoof's Avatar
Farhoof Farhoof is online now
Default Re: NEW Avid SYNC X
Originally Posted by lucienpalmer View Post
That would be a GREAT feature! Lately, I've found myself having to switch between 5.1 in-the-box mixes at 23.98 and Atmos mixes at 24fps to an RMU. It takes quite a bit of effort. PT I/O changes, DADman outputs reconfigurations, on/off RMU connection in Peripherals, plus the frame rate switching....
1. Change the frame rate on the AJA video gen
2. Change the frame rate in the Renderer prefs
3. Change the frame rate on the RME TCO/MADI cards
4. Change the frame rate on Pro Tools Sync Setup to change Sync HD
In all, it's well over a dozen clicks just to get a session to load and play. I set up SoundFlow to take care of some of the output switching, so anything to automate even two steps of the frame rate dance, would be welcome.
Exactly! Auto changing framerate would actually be the only reason for us to upgrade. We have plenty of people dry hiring the studio. We'd like it to be fool proof where the entire setup is adjusted according to the session that is opened. Instead of telling someone to go tot he machine room, find one of the many small AJA/BM boxes with your current studio number on it, bring a small flat screwdriver and fiddle with the dipswitches to set it to the correct frame rate. In PAL country we use both 24fps and 25fps a lot.
  #22
Old 04-26-2021, 05:32 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
You'd eliminate a lot of this trouble with Sync X since it has a built-in video ref generator. You'd still have to manually set video ref format in Pro Tools > Session Setup. But, you'd avoid those machine room trips to change external video ref generator settings.
And, while we're on the subject of Session Setup, what do you guys think about having presets in that window for quickly changing settings based on project type?
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #23
Old 07-03-2021, 10:51 AM
MarkH MarkH is offline
Originally Posted by K.I. View Post
Hi.
I was using 10M. You can enter 10M directly. it's the best. The sound changes.
It is good that the word out of SYN X is output even when PT is not started. MTRX always synchronizes.
When you say enter 10M directly, are you suggesting Atomic out from 10M to 10Mhz/AES3id in on Sync X?
  #24
Old 07-07-2021, 07:18 PM
mattrixx mattrixx is offline
Yes, this would be great!!!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Avid Sync HD, $800 lucienpalmer Buy & Sell 1 08-27-2019 07:27 PM
Avid Sync I\O Raemond Cook Getting Started 12 02-21-2019 02:57 AM
Avid Sync IO HDXSound Pro Tools 12 20 05-30-2017 04:53 AM
AVID Sync HD won't generate 23.976 LTC jim33 Pro Tools TDM Systems (Mac) 1 01-20-2012 10:20 AM
AVID / PT sync - Help Iamrod Pro Tools TDM Systems (Mac) 3 05-17-2001 01:33 PM
