#61
2022.7.0 MIDI Problems
in 2022.6 and 2022.7 I have had midi issues. Everything will work fine for hours. Suddenly I can't move midi notes, delete them, change velocity, etc. I can however create new midi notes, but once they are in place they can't be modified. Has anyone experienced this? Im not a midi expert - its possible I am accidentally activating some midi lock or something, but I don't think so. Restarting Pro Tools fixes the issue for a while.
#62
Weirdest Midi thing ever..
Did I miss a new feature or is this a bug; when I move midi from one track to another I can`t edit it anymore..
super weirdo thx for help this is kinda urgent Protools 2022.7 on a M1 Macbook pro with 12.4 |
#63
Re: Weirdest Midi thing ever..
Yes this is a confirmed bug in 2022.6/7 that is affecting others on both Mac & Windows.
Hopefully, it will get fixed soon. But for good measure, please submit a case regarding your issue. As a workaround when this happens: Temporarily switch the track to sample mode, carry out your edit and then switch back to tick mode. (Assuming your were in tick mode when the bug occurred) I experience the bug in tick mode but very rarely in a new session. If notes do become stuck, switching to sample mode enables me to move/trim the notes. After which, I can switch back to tick mode. Try this before restarting the session. Otherwise, you MIGHT get an error when closing the session and lose 5 minutes of work (or whatever your backup is set too). That's happened to me only once so far.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 08-16-2022 at 03:52 PM. |
#64
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#65
Re: MIDI Weirdness Persists in 2022.7
Is there a consistent phrase/ bug tracker at Avid that we can use to make sure all of our support requests are recognized and collated? I am troubled by the same issues and would like the MIDI weirdness addressed ASAP. When filing a support ticket, what words will they readily recognize?
#66
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
#67
ok could you check this: just close and reopen the session - I know it sounds crazy but for me it fixed the problem (at least in the song I`m working on right now)
#68
There's definitely something to what you are saying.
#69
I've benefited from your posts as well. Glad to hear that you are able to go forward in your sessions using the latest version. Looking forward to a fix also. Fixing this without trading one bug for another would make it the keeper version.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
#70
As this seems to be an issue caused by certain older versions of PT, has anyone tried re-importing the session data into a new project?
This might be a more robust way of fixing the issue (backwards compatibility may be an issue tho').
Studio: Mac Pro | OSX Monterey | PT 2023.9 HDX | DAD AX32 Remote: Macbook Pro | OSX Ventura | PT 2023.9 Ultimate | UAD X8 |
Can't select midi notes after trimming midi clip | jpbm22 | Pro Tools | 5 | 04-17-2023 10:37 AM |
Quantizing is muting midi notes | rickbail | Pro Tools 12 | 3 | 10-09-2018 05:47 AM |
mass select of notes in midi editor | stainless | MIDI | 4 | 08-20-2010 08:00 PM |
MIDI Select/Split Notes - Assertion in PT8 | gonzolagonda | Pro Tools TDM Systems (Mac) | 3 | 08-18-2009 05:34 AM |
MIDI "Select notes" tool problem | GeneOuse | Pro Tools TDM Systems (Win) | 2 | 04-27-2005 12:27 AM |
