Old 08-18-2010, 01:27 PM
stainless stainless is offline
Default mass select of notes in midi editor
OK, I'm kinda new at Midi (I resisted for years...)
Is there a quick way to select groups of notes in order to do a mass transpose?
I have found several times now that midi parts (especially percussion) done else where and imported in, doesn't always translate the same (their closed hat is now a wood block, etc)
clicking on a note, holding down shift (I think that's the one) selecting the next not is rather tedious
"select all" seems to select the entire region, but not allow me to move the notes.....
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 08-19-2010, 01:08 AM
tonwurm's Avatar
tonwurm tonwurm is online now
Default Re: mass select of notes in midi editor
clicking a key on the keyboard at the left side will select all notes of that pitch
MP 5,1 12core 3.46ghz 96GB
PT Ultimate HDX, Logic, DP, VEPro
MacBook Mainstage
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 08-19-2010, 08:11 AM
flommer flommer is offline
For Drum MIDI, you should consider the option to import as one note per track. This will make a unique MIDI track for each drum sound. This has pros and cons, but it does make drum editing a little easier, including the problem you mention.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-19-2010, 09:35 PM
Steve@ZooWest Steve@ZooWest is offline
Both posters have good ideas for you.
As to a mass transpose, though it may not be what you need in this case...You should be able to drag across/highlight all notes with the smart tool... and transpose. Done it hundreds of times. Shouldn't be an issue, although what you need to do is more complicated than a simple transpose.
MIDI mapping is useful of course, and the single note thing with some editing can be acceptable. For example you might use single notes, except for hat stuff, which should all be in the same general area of the keyboard (erase all notes above and below the hat stuff on a copy of the whole original track). And perhaps rinse and repeat for toms.
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 08-20-2010, 09:00 PM
Flommer where is /how do I import one note per track?
I'm working with someone with a very early Midi composer program and he has limited save as/export options- at best I get individual tracks of his "patches" which have titles such as "Kieth Moon", "Sonic Ice", "Big Stick"...
I have figured out how to move/transpose groups of notes... but if there's any "hits" that don't need to be transposed in the group i have to individually move them back... which is very time consuming
Showing MIDI Notes Being Played While in MIDI Editor Window? ianbee Pro Tools 10 12 10-12-2016 07:39 AM
Notes played in Midi Editor Nullifer Pro Tools M-Powered (Win) 2 04-01-2011 03:04 PM
Can you tag the notes in midi editor? Jonasfp MIDI 8 12-16-2009 06:28 PM
MIDI Select/Split Notes - Assertion in PT8 gonzolagonda Pro Tools TDM Systems (Mac) 3 08-18-2009 06:34 AM
MIDI "Select notes" tool problem GeneOuse Pro Tools TDM Systems (Win) 2 04-27-2005 01:27 AM
