Old 07-07-2009, 04:26 PM
rymoran rymoran is offline
Question Weird, inconsistent Loop playback - WTF???
Hi All:
I'm perplexed by the looping feature in Protools. I have loop playback selected as indicated by the play icon with the loop arrow showing.
If I select a region, sometimes it will loop, othertimes it will not. At first I thought the loop feature only applied to a single region and not a selection comprised of many smaller regions, but this too does not seem to be consistent.
Right now, in the file I have open, I can not get anything to loop on playback. The selected region simply plays once and then stops. Rather annoying for drum programming.
I have tried highlighting a chunk via the global tracks at the top, selecting a region and highlighting multiple regions. None of these seem to aid looping.
Yet sometime the program loops just fine.....
Any insight into this issue?
Thanks
R
Old 07-07-2009, 05:52 PM
Giles Reaves Giles Reaves is offline
Default Re: Weird, inconsistent Loop playback - WTF???
Do you have a track in record when it won't loop? That is one predictable way to not have looped playback even when "Loop Playback" is enabled.
Originally Posted by rymoran View Post
Hi All:
Thanks
R
Giles Reaves
Somewhere Between Tennessee & Utah...
Old 07-07-2009, 08:48 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Evergreen Audio Design Group
There are a few things you might want to check...
Pro Tools will only loop if the play selection is greater than or equal to 1/2 second. I would guess this is not your problem, but I thought I would mention it.
Do you have your edit and play selections linked?
We loop on play selections by default rather than edit selections.
Are you in "Dynamic Transport" mode?
Right click on the play button or loop under the Operations menu. This can make looping work a little different. It takes into account the little blue triangle and where that lines up to the play selection.
Old 07-08-2009, 05:43 AM
tamasdragon tamasdragon is offline
Other thing to check accidently hit n key?
Tamas Dragon
my blog:Tamas Dragon
Inconsistent Tempo/Playback slows down,speeds up perfectdrug6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-19-2011 03:56 PM
weird Loop Playback/Groove Problem perfectdrug6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-20-2011 09:39 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
PTLE7.1 - Weird and inconsistent Midi K Bartos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2006 01:54 AM
Transport Window inconsistent stopping playback beverlysfield 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-18-2005 11:18 AM
