Help with tempo change please
I imported a audio drum file to record guitar over and it has several tempo changes that need to happen, 120 - 110 - 120 - 155 - 120 and such, when I add tempo change markers they show up and it shortens/lengthens the bars after it and even says it changes in the transport when playing it but it never actually changes it still plays at the 120 default tempo the whole track, I read somewhere to change the track to ticks instead of samples and I did that and it still did nothing, I have also tried every type of elastic audio on sample and tick based track and it still hasn't worked. Someone please help this is killing me.
Re: Help with tempo change please
So the tempo changes are already in the drum track (the file itself), or you are trying to make it conform to tempo changes?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
The tempo changes are not in the file itself I am trying to make the tempo changes happen to the audio drum track which is all by default 120 tempo.
I think you need to change the order you are doing things
First turn on Elastic audio, Second change from samples to ticks Then put your tempo changes in the track See if that helps...
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Thanks so much it did work
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Ramping a Tempo Change (interpolation or discrete tempo points) | edgarbc1 | Tips & Tricks | 3 | 02-18-2009 12:55 PM |
Tempo Change w/out moving other tempo changes | pietro79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-20-2006 09:00 AM |
Tempo change without pitch change for audio | layman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-16-2002 07:14 PM |
