Trouble opening TDM session in LE
Can anyone help with this:
A session recorded in a TDM system won't open properly on LE (M-Box). It complains that some files don't have the unique identifier and does not accept the correct files. I have only found reference to track number and plug-in limitations on the Digi website. I have a TDM system 5.1.1 in OS 9.1. The LE system is 5.2.x in OS 9.2. |
Re: Trouble opening TDM session in LE
try this once you have opened the session file...then import the audio files back into the session...hopefully they have all been consolidated properly and they should slide right in.
www.garyvandy.com |
Strange...
I did this several times and never had this problem (PT 5.1.1/Mix/TDM/MacOS 9->PT LE 5.2/MBox/MacOS 9.2 and vice versa). Are all audio files copied into your hard drive? [img]images/icons/cool.gif[/img] |
Sometimes this problem happens on a TDM system. Did you copy the session on your hard drive?
1.Try changing the drives. 2.Create new session file and import track option under file menu -import all the files at once. 3.Maybe you those files with wrong identifier are not used in the session. [img]images/icons/wink.gif[/img] [img]images/icons/cool.gif[/img]
Don't confuse kindness for weakness |
Thanks for the advice, we fixed the problem today after much experimentation. Importing tracks etc didn't work because PT still wanted the "unique identifier". This was the problem, can anyone explain why?:
The client with the LE M-box system had loaded all files and session onto his drive. Next he did some other work in OSX. Then back to OS 9.2 and tried to open the session that wouldn't recognise its files. Today he simply re-loaded all audio onto his drive and *voila* it works! Does OSX put something on the file or tree that PT does not recognize? Thanks again, Lee (Perth, Australia) [img]images/icons/smile.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/smile.gif[/img] |
trouble Opening a Session | SilveradoRecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-13-2005 10:53 AM |
Trouble opening a session in Protools 5.0.1 | eep013 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-30-2005 08:34 PM |
Trouble opening 6.1 session w/10.2.8 | Steve58 | Pro Tools TDM Systems (Mac) | 0 | 12-05-2003 06:31 AM |
Trouble opening TC session | chrille2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-07-2003 10:07 PM |
Trouble opening XP PTLE session on M-Box | orage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-10-2002 05:15 PM |
