Old 05-18-2022, 03:32 AM
danyg danyg is offline
Default Ultimate automation
hi, how can avoid this message (from automation)
I have seen tutorial videos where it doesn't come up all the time
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 05-18-2022, 03:55 AM
Cheesehead Cheesehead is offline
Default Re: Ultimate automation
You need to use a macro app like Soundflow or Keyboard Maestro to automatically close it.
That's probably what they are using on the videos you've watched.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-18-2022, 04:31 AM
Led Led is offline
You can turn off the automation warning in the preferences
Old 05-18-2022, 08:01 AM
originalscottyg originalscottyg is online now
Those warnings can be useful because there is a feature (BUG), where the automation will write across the entire SESSION, if you make a selection after starting playback. Unfortunately, the warnings pop up both when things go wrong (writing across the entire session when not intended), and when things go right (selection is made before playback is started and automation is only written to the intended selection).
Suppressing those warnings in the preferences eliminates both warnings, leaving open the possibility of inadvertently writing automation across the entire session and destroying hours of work; automating dialog clips, for example.
Somebody had written an app called Guardian Angel, that only suppressed the non-useful warnings and left up the useful warning (determined by the size of the pop up window). But I had pretty erratic results with this and had to resort to leaving up all the warnings.
Scott Gatteño
Old 05-19-2022, 11:57 PM
got it, thanks everybody for your help
Old 05-20-2022, 04:45 AM
I used to use Guardian Angel too, but now Soundflow has a macro that also only suppresses the benign warnings.
It's still a terrifying thing that you can blow away hours of automation work by not making a selection.
Old 05-20-2022, 12:21 PM
smurfyou smurfyou is online now
I’m surprised no one has asked Avid to fix that
~Will
Old 05-20-2022, 02:05 PM
basehead617 basehead617 is offline
Can someone explain what this error message means and how it happens?
Old 05-20-2022, 02:15 PM
DavidHeylen DavidHeylen is offline
I thought I was the only sucker with finding out later in a session that my automation is f@cked.
www.literecordings.be
Write to all enabled automation command--still Ultimate only feature? zboy2854 Pro Tools 2020 2 01-12-2022 02:52 AM
AudioScore Ultimate is in Sibelius Ultimate? bhs67 Getting Started 0 11-22-2020 08:44 AM
Bought PT Ultimate reinstatement, can't activate Ultimate subbasshead Licensing & Accounts 3 11-29-2019 09:23 PM
Native Instruments Komplete 11 Ultimate Update from Komplete Ultimate 8-10 joepopp Buy & Sell 0 09-25-2019 07:16 AM
Vista Ultimate 64 (the ultimate dissapointment) Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2009 04:44 AM
