Rewire problems
Hello everybody.
I have an imac 10.4.11 with pro tools version 7.3 and reason 3. all legit, no pirateware or anything like that. This is my clients machine...I've never experienced anything like this. No matter what, Reason will not show up in Pro tools. Reason recognizes the mbox2, but doesn't rewire as a plug-in. I've tried everything I can think of. Has anyone else experienced this or can point me in the direction where I can fix this? thank you P.s. I installed the latest rewire version 1.7 and I copied the plug-in and moved it to the application support folder in digidesign/plug-ins what else should I do? I've tried everything. thanks |
Re: Rewire problems
Have you launched the application in standalone mode. This is a one-time excercise that's required to install certain Rewire components.
http://www.myspace.com/philogg |
Re: Rewire problems
yes....
I just installed reason 4 because I thought that it would work instead of three and I'm having the same problem. At the end of the reason installation it said something about rewire being locked and it was unable to move??? This is the problem. Pro tools is not recognizing reason. Reason is registered, installed, and works fine (it uses the mbox hardware, I can see that) The problem is rewire. How can I make this work? It's menacing |
Re: Rewire problems
yes....
rewire problems | perraultm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-10-2012 03:52 PM |
Rewire problems | Deano1974 | Pro Tools SE and Essential (Win) | 0 | 03-26-2011 03:02 PM |
rewire problems | garrydrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-29-2008 04:47 AM |
Rewire problems | JM999 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-17-2006 12:16 PM |
Rewire Problems | Buzzhound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-09-2003 09:28 AM |
