I have a Gateway MX6920 w/ XP Pro and a Maxtor OneTouch III external fire wire drive and an Mbox 2.
I've done all the required system optimizations. When I install PT LE I get errors saying that this software is not Windows Logo Verified to be Compatible with XP. It asks me if I want to continue then the install goes fine. When my computer reboots my video driver is disabled. Then on another reboot I will get something like 680 x 420 display @ 4bit resolution! I tried reinstalling the video drivers and I get some kind of blue green screen with a bunch of script for a half second and then it reboots. I thought at first it was the OneTouch after reading bad reviews but after a system restore and reinstall of PT LE I realised it is not the Hard Drive. Please Help! |
The Windows Logo message is described in the Getting Started Guide/installation instructions for every version of PTLE/hardware.
You ignore it and click to proceed. A full system summary from Sandra software (as recommended in the General Troubleshooting thread) may be helpful. Exactly what system optimizations have you done? Have you verified your computer from the Compatibility documents? At least one version of your laptop comes with a Celeron processor... which is not supported. |
It has an Intel T2050 Dual Core. 1 GB RAM, 120 GB 5400RPM SATA.
Everything seem to work fine afterwards. I even got the drivers updated but the Intel Media Accelerator won't load and the screen looks like crap. Windows still thinks that the driver and all the hardware is working fine. |
![]() Quote:
Sorry for the short reply, busy day.
I don't have my manual with me at the moment so I might have trouble remembering what I changed. I changed the processor scheduling for background services, memory usage to system cache, I disabled my power saving schemes, and prior to buying Pro Tools I have cleaned my system and registry with WinXP Manager. After doing a system restore everything would work fine again but I would lose Pro Tools (restore point was before the installation). I wanted to to try something out so I undid my restore point and for whatever reason everything worked fine. After realizing that I had to do a clean install of Pro Tools to upgrade from 7.0 to 7.1 I installed 7.1 from scratch only to have my display problem reoccur. I then did a restore to before I installed 7.1 and my display is fine again. So for the moment I have 7.0 installed, just the basic program. I opened it and it ran fine but I did not have a chance to try out a session. I don't really trust the stability of it seeing how I haven't even figured out why it's working now. To me if I can't explain why it's working properly, it probably isn't. |
SiSoftware Sandra
System Host Name : IM-WATCHING-YOU User : Neil Workgroup : WORKGROUP Processor Model : Genuine Intel(R) CPU T2050 @ 1.60GHz Speed : 1.60GHz Performance Rating : PR5426 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : ISA PCI PCIe PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : No System BIOS : Gateway 77.05 System : Gateway MX6920 Mainboard : Gateway Total Memory : 1015MB DDR2-SDRAM Chipset 1 Model : Gateway 2000 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller Front Side Bus Speed : 4x 133MHz (532MHz data rate) Total Memory : 1GB DDR2-SDRAM Shared Memory : 8MB Memory Bus Speed : 4x 133MHz (532MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Monitor/Panel : Plug and Play Monitor Monitor/Panel : Plug and Play Monitor Adapter : Mobile Intel(R) 945GM Express Chipset Family Adapter : Mobile Intel(R) 945GM Express Chipset Family Physical Storage Devices Hard Disk : WDC WD1200BEVS-00LAT0 (112GB) CD-ROM/DVD : PHILIPS DVD+-RW SDVD8820 (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 112GB (101GB, 90% Free Space) (NTFS) Pro Tools LE (D:) : 479MB (CDFS) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Texas Instruments PCIxx12 Cardbus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port TouchPad Communication Device(s) Device : Motorola SM56 Data Fax Modem Printers and Faxes Model : Microsoft Office Document Image Writer Model : HP Photosmart C4100 series Power Management AC Line Status : Off-Line Battery No 1 : 73% Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Generic Marvell Yukon Chipset based Gigabit Ethernet Controller Adapter : Intel(R) PRO/Wireless 3945ABG Network Connection Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Why is there a 479MB partition (D:) named Pro Tools?
That's the installation CD.
DUH... thanks Shawn.
MBox 1 Installation Corrupts MBox 2 Installation. Any Ideas Short Of Reinstalling OS? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-01-2009 07:03 AM |
Help with Mbox 2 installation!! | $tereoimage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-26-2007 11:17 AM |
Help me please!!! - MBox 2 installation | nathanjar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-19-2007 01:16 PM |
002 on a mbox installation | siroj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2007 03:42 AM |
Installation On MBox | Liam M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-16-2006 03:15 PM |
