Track freeze?
er, do we have it with pro tools? i cant seem to find anything saying that there is the track freeze option.
Mac Pro 3.2 Ghz Quad, OS 10.13.3, 48 G RAM, UA Apollo Duo, PT 12.8.3 |
Re: Track freeze?
Nope! you need to use Audiosuite plugins to render the effects to your tracks. This will free up valuable CPU cycles.
Re: Track freeze?
But keep in mind, if you, for example, process an EQ with AudioSuite, you can't remove it later, as I believe you can in Logic....? So if you need to be able to do this, make sure you apply the EQ, or other... to a duplicate take of your track...
Re: Track freeze?
Yep,
1) Save your RTAS settings. 2) Create duplicate track. <-- EDIT: should read duplicate playlist. 3) Load up the corresponding AS plug-in varient. 4) Recall settings. 5) Process. Sorted. Of course, a "Freeze" function would make life less green on the other side of the fence.
SoundPunk | Pro Tools Tips & Tricks |
Re: Track freeze? *DELETED*
Post deleted by RadioMoo
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM |
Re: Track freeze?
I never said the parent file was deleted. I was just saying that, since most of us do more than push record at the start of a session, track a song, and push stop before we mix, it is a more complicated process.
My tracks typically have many cuts, pastes, edits, comps etc... How would you ever reassemble this from your file list?!? You'd have multiple parent files and they don't all start from one starting point. It'd be impossible. Also, by the time you discover that the EQ, or other you applied isn't just right, you'd be undoing through 20 or more minutes of work to revert back, then working ANOTHER 20 mintues to get back to where you were... Just duplicate your playlist on the track your working with, then click anywhere on the track, hit cmd + A and process it all. That's the easiest, most-flexible way. |
Re: Track freeze?
Have to agree with Boosix here. Duplicating and using AS plug-ins really helps free up cpu power. But then again, after going to PT7LE, I haven`t maxed out my CPU once yet..
Stian Sylta Producer/Songwriter/Musician Sons Of Vanity on iTunes/Spotify MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12 Preamps from UA, Mackie and Avid. Listening through Dynaudio, Genelec and ADAM |
Re: Track freeze?
I don't get your post, Radiomoo. Booksix presents the more elegant solution, using a duplicate playlist. He is taking advantage of Pro Tools' powers.
If I'm wrong I would enjoy the education-- PC
I don't know karate but I know KA-RAZY! |
Re: Track freeze?
If you need to freeze Insturments traks (no AS available) you can:
1. route outs to an audio track (using busses, of course); 2. bounce your tracks (solo button required); 3. buy a software like silverspike tapeit 2 or download the free version of tapeit 1.0; |
Track-freeze? | rossi68 | Pro Tools 11 | 4 | 10-14-2013 04:36 AM |
track Freeze in PT | bbbkink | Windows | 10 | 12-11-2012 09:10 PM |
OMG, check this out ...track freeze in pt | mingustoo | Tips & Tricks | 10 | 12-31-2008 05:28 PM |
Track offset menu or track freeze as workaround for ADC? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-27-2008 12:19 PM |
freeze track? | boot | Tips & Tricks | 5 | 07-05-2008 08:08 AM |
