Old 12-25-2011, 08:38 AM
composer123 composer123 is offline
Default Audio Suite Plugins won't work
I haven't used ProTools on my computer in a few years. I came back to it the other day and found the plugins pretend to process (ones like pitch shift, or reverb, I've tried several and none work), but when I play it back, nothing was changed. It will preview it properly as well. I can add reverb as a plugin, and it will work dynamically, but if I want to select a portion and change just that, nothing happens. (No error message either). (Unfortunately, pitch shift is not available as a dynamic plugin, there's no normal reason why one would need it.) I am afraid it may be one of the several Java updates I've had over the years, but I am hoping someone might know of a setting that can be changed. Here's what I am running:
Mac OS X 10.4.11
(Intel-based, 2GB RAM)
Pro Tools 7.1.3
MBox 2 Pro
The plugins are the basic ones that came with ProTools when I bought them.
If there's nothing that can be done about that, perhaps someone can help me with the slightly humorous but annoying problem for which I am trying use Pitch shift:
I recorded a live event on someone else's Macbook, ProTools 8. Because we didn't have the option of saving the session as PT7 session, I just took the audio files and burned them onto CD as wave files. Then I imported them into a new session on my computer. The result? everything was 1.25 semitones higher and the voices sound a little munchkin-ized. The original should be fine, but the owner is going back to college in a week, so I really need to figure something out quick. Any suggestions, apart from spending a week with him and his family as I edit on his computer? :)
Old 12-25-2011, 11:26 AM
Sparky1 Sparky1 is offline
Default Re: Audio Suite Plugins won't work
Originally Posted by composer123 View Post
I
Sounds like one session was set at 44.1 and the other at 48? Try changing your session rate.
Sparky
Old 12-25-2011, 12:14 PM
Forgot to suggest try trashing preferences for your first problem...
Sparky
Old 12-25-2011, 12:43 PM
Select "Use In Playlist" in the AudioSuite header.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-25-2011, 01:29 PM
Sparky
Thanks! This worked.
Old 12-25-2011, 01:31 PM
Sparky
Oh, right, that makes sense. Next time (if there is one) I will make sure the sampling rate matches.
Old 12-25-2011, 01:32 PM
Rail
I meant to reply to the "Use in Playlist" suggestion when I said it worked. I am sure the session rate caused the issue to begin with, but the Use in Playlist allowed me to correct the plugins issue.
Audio Suite plugins that work in 10, do they work in 11? David Sandwisch Windows 1 08-10-2013 08:14 PM
Will older Audio Suite plugins work in PT11? mgoorevich Post - Surround - Video 3 04-08-2013 04:14 AM
Audio Suite Doesn't work? AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-14-2009 09:37 AM
Help! Audio Suite doesn't work polaredit Pro Tools TDM Systems (Mac) 0 06-05-2003 09:42 AM
Noisy Audio Suite Plugins? SteveGarman Pro Tools TDM Systems (Mac) 5 11-07-2000 07:44 PM
