11R slamming my monitors on startup.
I have gone WAY simple in my studio and disconnected the line mixer and all the peripherals, even the computer audio channel. I want to wring the best and the quietest audio I can out of my system while I try to figure out computer and interface choices. I ditched the 002R that 11R was S/PDIF'd into and my 11R Main Outputs go directly to my Event 20/20 bAS monitors.
Everything is hooked into a power conditioner and all the gear switches are set to ON as are the Event powered monitors. Before, I would turn down all the channels on the line mixer before turning ON the power.......no problems. But now....... ......even with 11R's Volume all the way down......I get this really awful and LOUD pop out the monitors. So I tried turning 11R OFF and then turning on the system and monitors.....then turning on 11R ....BAM!!! .......loud pop. I suppose I now have to awkwardly reach behind my monitors everytime and turn them off and on before 11R. What a pain!! Does anyone else experience this?
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Re: 11R slamming my monitors on startup.
I use a Monster 2500 power conditioner and it has a delayed power on for some outlets that I put on my powered monitors. It also shuts down in the opposite order. This solution works for my 11R setup.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Why do you keep turning it off then?
I've only had mine for about 9 months, but i never turned it off. |
The pop is normal. You need to follow normal amp procedure; main amps are last on and first off. It's the same for your active monitors - last on and first off. Don't let them pop.
Turn on the 11R first, then everything else, then turn on the monitors. This issue has been raised several times on the forum http://duc.avid.com/showthread.php?t...light=loud+pop
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Dude......in my small studio here in California.....once the powered monitors, computer, studio lights, any guitar amps etc and the computer monitors....yes that Apple Cinema Display generates some heat.....have all been on for an hour or more......it gets to be a sauna in there. I run the A/C in winter when I am working long hours in the studio. Also......everything was on one power switch. I would come in, flip that switch, turn on the computer and be good to go. As long as the mixer main volume was down.....no pops. That is with the 11R connected to 002R by S/PDIF. And the few times I made the mistake of not checking the mixer volumes were down....I would get a crackle....higher pitched pop....in the tweeters mainly. This pop was more like a sonic boom compared. Hit the woofers also........WAY loud!! I'm surprised nothing got damaged. So yes.......I will follow "normal amp procedure" in the future. Quote:
Okay read the link. So yeah, my only comment is that you would think with all the advances in technology......this could have been fixed by now. Not just Digi/Avid.....but in all equipment that suffers from the power up spike that slams amps, audio monitors etc. That is all I have to say about that.
SONAR Slamming Pro Tools in the Recording mag | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2007 04:38 AM |
Make Studio Monitors as Desktop Monitors through Mbox2 ???? | dcwang3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-17-2007 08:02 AM |
Monitors: $1500-$1800 budget . Which Active Monitors? Suggestions and Help Please. | betsy | Pro Tools TDM Systems (Mac) | 52 | 12-15-2003 10:11 PM |
Choose startup disc ---at startup???? | meshtheflesh | Tips & Tricks | 3 | 12-15-2001 08:07 PM |
mac startup ? can't find startup disc | peterfitz | Pro Tools TDM Systems (Mac) | 1 | 03-24-2000 08:27 AM |
