#21
Re: 11R For Live Sound?
For the people that have complained in the past about the .06 second lag, I wonder in which mode they were switching? I went from 11R to Kemper and gigged the Kemper. If you want massive lag, try switching the Kemper rig to rig in Browse Mode. That my friends is serious lag. I've since gone back to gigging a mic'd tube amp. |
#22
I have only used my 11R live when I owned it until 2012, and since I bought it again in March 2014. I always switch presets (I play mostly top40 stuff, so the need for many sounds is evident), I have always done that via MIDI, but never had problems with delays in switching. I have to say I don't switch during a held note or similar (if I had to I would try to solve that with my exp pedal and assign the necessary changes to that rather than switch the preset - but I would go that route anyway, with or without switching delay, since it is smoother).
#23
What did you use for an amp/powerhead?
#24
I ran one Main XLR mono direct out into mixer/PA amp. For a stage monitor I used a QSC K12.
As I mentioned in this forum in the past the only issue I ever had live (depending on the venue) was a classic "boomy" feedback. Eventually I cut the offending low frequency by applying the same para eq setting to all my rigs. I don't remember the offending frequency. |
#25
OK that helps. Can you recommend a foot switch? I don't need a lot of switches, maybe 4 switches and a pedal to which i can assign parameters would be nice. (I'm assuming the 11R lets you assign parameters to a pedal anyway)
I need something with nice, big switches (not like Line 6's tiny, crowded buttons for example) |
#26
I've only used the MidiMate in Bank Mode. In Bank Mode it switches from Rig to Rig. I've never used it in Controller mode (ability to switch on/off individual effects.) The only negative thing I've heard people say about the MidiMate is the plastic stomp buttons but they don't bother me. |
#27
I run the 11R live with a Pod HD500 Pro in the 11R Send/Return.
The 'Output To Amp' on the front goes to the AC30 and I give the sound person the XLR output as a secondary channel. He/she can mix both or choose or if the amp suddenly died I could keep the show going direct. The 11R has a much better AC30 sim than the HD500. This approach has not failed. I use the Ground Control Pro to switch. It can switch 8 devices on different MIDI channels. I actually run our theatre software from it in addition to the guitar effects. I send the Start cues with it. The 11R has been great for me and with the HD500 is a much better cost to benefit ration than the AXE-FX. |
#28
Going direct to 2x Yorkville NX55P with matching sub: incredible sound. We add 1-2 Mackie SR1530 when we need more.
#29
So is the 11R pre-loaded with the editor software that works in Protools, or is there an iLok authorized download, or what? I haven't seen anything saying the unit comes with a disk of software (not Protools software but the one that has the FX, stomps, amps, etc to run on your computer). I hope I'm making sense. I'm not totally sure what it is I'm asking for.
#30
And to be clear this is just a rig editor to edit the Eleven Rack settings. It is not a bunch of plugins that run effects on your computer or with a DAW etc. (which it seems like you might be asking for). You don't need the editor to do anything, you can do it all via the front-panel, it just makes it easier to do things. And for live sound, you may not want a computer attached to your Eleven Rack, you more likely want a MIDI pedal board attached.
Live sound | popcornmama | VENUE Live Sound Systems | 1 | 10-30-2006 01:43 PM |
OT: help with live sound | metaltim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-26-2005 03:45 PM |
Live sound | Tom Case | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-29-2005 02:52 AM |
Live sound mixing (distorted mic sound) | technician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-25-2004 04:52 AM |
Live No Sound | SIRE | General Discussion | 0 | 02-23-2004 09:29 PM |
